samsung np-rv411 scala2-ext_rev1.1 schematic
samsung np-rv411=1=scala2-ext_rev1.1.pdf
The Samsung N11X-GE2/GE1 motherboard, project code SCALA2-EXT, board number BA41-01423A revision 1.1 dated December 25, 2010, is built on the Intel Calpella platform featuring an Arrandale PGA CPU paired with the Intel Ibex Peak PCH. System management is handled by an SMSC MEC1300 EC/KBC. Audio is provided by a Realtek ALC269Q codec, while networking is managed by a Realtek 8111E LAN controller and a Marvell 88E8040 WLAN IC. Storage connectivity includes a GL823 card reader controller. Power management and charging are controlled by an EMC2112 charging IC. The board supports dual-channel DDR3 SODIMM memory across two slots. Thermal monitoring is performed by a TS998 thermal sensor. USB expansion is supported by an AU6437 USB hub IC.
Q: What EC/KBC is used on this Samsung N11X-GE2/GE1 motherboard?
A: The motherboard uses an SMSC MEC1300 EC/KBC.
Q: What audio codec is present on this board?
A: The audio codec is a Realtek ALC269Q.
Q: What LAN and WLAN controllers are used?
A: The LAN controller is a Realtek 8111E, and the WLAN IC is a Marvell 88E8040.
Q: What is the memory configuration of this motherboard?
A: The board supports dual-channel DDR3 SODIMM memory across two slots.
| Brand | Samsung |
| Model | N11X-GE2/GE1 |
| Motherboard Manufacturer | Samsung Electronics |
| Project Code | SCALA2-EXT |
| Board Number | BA41-01423A |
| Revision | 1.1 |
| Date | December 25, 2010 |
| CPU Platform | Calpella Platform |
| CPU Model | Arrandale PGA |
| PCH / Southbridge | Intel Ibex Peak |
| EC / KBC | SMSC MEC1300 |
| Audio Codec | ALC269Q |
| LAN IC | Realtek 8111E |
| Card Reader IC | GL823 |
| WiFi / WLAN IC | 88E8040 |
| Charging IC | EMC2112 |
| RAM Type | DDR3 SODIMM |
| RAM Architecture | Dual channel |
| Thermal Sensor | TS998 |
| USB Hub IC | AU6437 |
SCALA2-EXT
BA41-01423A
Calpella Platform
Arrandale PGA
CPU Model
SMSC MEC1300
/ ALC269Q
8111E
GL823
88E8040
EMC2112
DDR3 _SODIMM
TS998
AU6437
SCALA2-EXT
BA41-01423A
Calpella Platform
Arrandale PGA
CPU Model
SMSC MEC1300
/ ALC269Q
8111E
GL823
88E8040
EMC2112
DDR3 _SODIMM
TS998
AU6437
