samsung np-x06 aquila-so rev1.0 schematic
samsung np-x06=1=aquila-so rev1.0.pdf
The Samsung X06 motherboard, board number BA92-03859A with PCB code X06BA41-00529A, revision MP1.0 dated June 25, 2005, is built on the Intel Alviso + ICH6-M platform supporting Dothan and Yonah CPUs. Graphics are handled by the integrated Alviso-GM internal graphics controller. The system uses DDR II memory in dual-channel configuration across two SODIMM slots. The EC/KBC is a MICOM implemented with the Hitachi HD64F2169/2160 microcontroller. The BIOS flash is a FWH type, specifically the ANT82802AC model. Audio is provided by an AD1981B AC'97 codec. Networking includes a BCM5788 LAN controller and wireless LAN support. The charging and card reader functions are managed by an R5C841 IC. A USB hub IC, the R5532V, is present. Thermal management includes a dedicated CPU/DDR thermal sensor.
Q: What BIOS flash IC is used on this Samsung X06 motherboard?
A: The BIOS flash is a FWH type, specifically the ANT82802AC model.
A: The EC/KBC is a MICOM implemented with the Hitachi HD64F2169/2160 microcontroller.
Q: What memory architecture does this motherboard support?
A: The motherboard supports DDR II memory in dual-channel configuration across two SODIMM slots (SODIMM 0 and SODIMM 1).
Q: What is the charging and card reader IC on this board?
A: The R5C841 IC handles both charging and card reader functions.
| Brand | Samsung |
| Model | X06 |
| Motherboard Manufacturer | Samsung |
| Board Number | BA92-03859A |
| PCB Code | X06BA41-00529A |
| Revision | MP1.0 |
| Date | 2005-6-25 |
| CPU Platform | Intel Alviso + ICH6-M |
| CPU Model | Dothan (w/533MHz) & Yonah |
| PCH / Southbridge | ICH6-M |
| GPU Type | Internal Graphics |
| Graphics Architecture | Alviso-GM |
| EC / KBC | MICOM |
| EC/KBC Package | HD64F2169/2160 |
| Audio Codec | AD1981B |
| BIOS / SPI Flash | FWH |
| BIOS Flash Exact Model | ANT82802AC |
| Charging IC | R5C841 |
| RAM Type | DDR II |
| RAM Architecture | Dual channel |
| RAM Quantity / Slots | SODIMM 0, SODIMM 1 |
| LAN IC | BCM5788 |
| WiFi / WLAN IC | Wireless LAN |
| Card Reader IC | R5C841 |
| USB Hub IC | R5532V |
| Thermal Sensor | CPU/DDR THERMAL SENSOR |
