samsung np350v qcla4-qcla5 la-8862p_rev 0.2 schematic
samsung np350v=1=qcla4-qcla5 la-8862p_rev 0.2.pdf
The Compal LA-8862P schematic, revision 0.2, dated 2011-11-24, documents the Eureka 14" & 15" platform. This motherboard is built around an Intel Processor (Ivy Bridge / Sandy Bridge) with an Intel PCH Panther Point southbridge. System memory consists of two 200pin DDRIII-SO-DIMM slots supporting dual-channel architecture. The embedded controller is an ENE KB930/KB9012 with a dedicated 128KB EC ROM. The BIOS is stored on a SPI ROM configuration of 4MB plus 2MB. Audio is handled by an ALC280 HDA Codec, while networking is provided by either an RTL8105E-VD 10/100M or RTL8111F-VB 1G LAN IC. A Realtek RTS5229 IC manages the card reader interface.
A: The board number is LA-8862P, and the project code is QCLA4,5.
A: The embedded controller is an ENE KB930/KB9012, with a dedicated 128KB EC ROM.
A: The BIOS is stored on a SPI ROM with a total capacity of 4MB plus 2MB.
Q: What memory architecture does this motherboard support?
A: It supports dual-channel DDRIII memory via two 200pin SO-DIMM slots.
| Model | Eureka 14" & 15" |
| Project Code | QCLA4,5 |
| Board Number | LA-8862P |
| Revision | 0.2 |
| Date | 2011-11-24 |
| CPU Platform | Intel Processor (Ivy Bridge / Sandy Bridge) |
| PCH / Southbridge | Intel PCH Panther Point |
| EC / KBC | ENE KB930/KB9012 |
| EC Flash / ROM | EC ROM (128KB) |
| Audio Codec | ALC280 HDA Codec |
| BIOS / SPI Flash | SPI ROM (4MB + 2MB) |
| RAM Type | DDRIII |
| RAM Quantity / Slots | 200pin DDRIII-SO-DIMM X2 |
| Card Reader IC | RTS5229 |
| LAN IC | RTL8105E-VD 10/100M / RTL8111F-VB 1G |
