samsung np350v5x qcla4 qcla5 la-8862p
This Compal LA-8862P schematic, revision 0.2 dated 2011-11-24, documents the Eureka 14" & 15" platform. The motherboard is built around an Intel Ivy Bridge or Sandy Bridge processor paired with the Panther Point PCH. System memory consists of two 200-pin DDRIII SO-DIMM slots supporting dual-channel architecture at 1066/1333/1600 MT/s. The embedded controller is an ENE KB930 or KB9012 with a dedicated 128KB EC ROM. The BIOS is stored on a SPI ROM configuration of 4MB plus 2MB. Audio is handled by an ALC280 HDA codec. Networking is provided by either an RTL8105E-VD 10/100M or RTL8111F-VB 1G LAN IC. A RTS5229 card reader IC is also present on this board.
A: The schematic specifies an ENE KB930 or KB9012 embedded controller with a dedicated 128KB EC ROM.
A: The BIOS is stored on a SPI ROM with a total capacity of 4MB plus 2MB.
Q: What memory type and configuration does this board support?
A: It supports DDRIII memory in a dual-channel architecture via two 200-pin SO-DIMM slots, running at 1066/1333/1600 MT/s.
Q: What LAN IC options are documented?
A: The schematic lists either an RTL8105E-VD 10/100M or an RTL8111F-VB 1G Ethernet controller.
| Model | Eureka 14" & 15" |
| Project Code | QCLA4,5 |
| Board Number | LA-8862P |
| Revision | 0.2 |
| Date | 2011-11-24 |
| CPU Platform | Intel Processor (Ivy Bridge / Sandy Bridge) |
| EC / KBC | ENE KB930/KB9012 |
| EC Flash / ROM | EC ROM (128KB) |
| Audio Codec | ALC280 |
| BIOS / SPI Flash | SPI ROM (4MB + 2MB) |
| Card Reader IC | RTS5229 |
| LAN IC | RTL8105E-VD 10/100M / RTL8111F-VB 1G |
| RAM Type | DDRIII |
| RAM Quantity / Slots | 200pin DDRIII-SO-DIMM X2 |
