sony mbx-215_mbx-235_foxconn_m931_irx-5300_rev-sa schematic
sony_mbx-215_mbx-235_foxconn_m931_irx-5300_rev-sa.pdf
The Foxconn M931 (MBX-215) is a Calpella platform motherboard designed for Arrandale and Clarksfield processors in a Micro-FCPGA-988A socket, paired with the Ibex Peak-M (PM55-B3) PCH. Graphics are handled by a discrete nVIDIA N11P or N11M GPU (N11P-GE1-A3 / N11M-GE1-A3) with dedicated DDR3 VRAM. System management is provided by a Winbond NPCE783L EC/KBC in a QFP-128 package, programmable via a dedicated 1Mbit SPI EC firmware flash. The system BIOS is stored on a single 32Mbit SPI flash. Audio is managed by a Realtek ALC275-A5 codec, and networking by a Marvell 88E8057 GbE controller. Power management includes a BQ24753 charger IC and multiple DC/DC converters (MAX17030, TPS51218, SN0608098, SC412A, MAX17028, G2998). Memory is supported via two SO-DIMM slots for DDR3. A Ricoh R5U231 card reader and a CK505 SL28748ELC clock generator are also present.
Q: What EC/KBC is used on this motherboard and is it programmable?
A: The EC/KBC is a Winbond NPCE783L in a QFP-128 package. It is programmable via a dedicated 1Mbit x1 SPI EC firmware flash.
A: The system BIOS is stored on a single 32Mbit SPI flash ROM.
Q: What discrete GPU options are available?
A: The motherboard supports discrete nVIDIA graphics using either the N11
| Brand | Foxconn |
| Model | M931 (MBX-215) |
| Motherboard Manufacturer | Hon Hai Precision Ind. Co., Ltd. / Foxconn |
| Project Code | M931 (IRX-5300) |
| Board Number | M931 Main Board |
| Revision | SA |
| Date | Wednesday, January 06, 2010 |
| CPU Platform | Arrandale & Clarksfield (Calpella Platform) |
| CPU Socket | Micro-FCPGA-988A (988-pin rPGA socket) |
| PCH / Southbridge | Ibex Peak-M (PM55-B3) |
| GPU Type | nVIDIA N11P/M Discrete Graphic |
| dGPU Chip Number | nVIDIA N11P-GE1-A3 / N11M-GE1-A3 |
| EC / KBC | Winbond NPCE783L |
| EC/KBC Package | QFP-128 |
| EC/KBC Programmable | EC Firmware 1M bit x1 SPI |
| Audio Codec | Realtek ALC275-A5 |
| BIOS / SPI Flash | System BIOS 32M bit X 1 |
| Charging IC | BQ24753 |
| Power IC(s) | MAX17030, TPS51218, SN0608098, SC412A, MAX17028, G2998 |
| RAM Type | DDR(III) |
| RAM Architecture | SO-DIMM 0 / SO-DIMM 1 |
| Card Reader IC | Ricoh R5U231 |
| LAN IC | Marvell 88E8057 |
| WiFi / WLAN IC | Mini-PCIE Card (WLAN) |
| Clock Generator | CK505 SL28748ELC |
| Thermal Sensor | TSL2561FN |
