sony pcg-51111w mbx-216_quanta gd3 schematic
pcg-51111w gd3-cb-atheros-pvt-1020a.pdf
pcg-51111w gd3-mb-evt-0601c.pdf
pcg-51111w=sony mbx-216 - quanta gd3.pdf
This Quanta Computer GD3 Main Board, revision 1A, dated October 20, 2009, is documented under Custom17. The board integrates an Atheros AR8131M LAN controller and an Atheros 8131M WLAN module. The schematic details support for Mini PCI-E cards for WLAN and WWAN, including a SIM card interface. The design includes a separate Charger Board sheet, revision 2A, dated October 6, 2009. The board features a G751-2P-8F temperature sensor and a GSL5009R-LF LAN transformer. Power delivery includes 3.3Vaux and 3VWAN rails. The WLAN radio is controlled via the WLAN_RF_ON signal.
A: The board is the Quanta GD3 Main Board, revision 1A.
Q: What LAN controller is used on this board?
A: The board uses an Atheros AR8131M LAN controller.
Q: What WLAN module is supported on this board?
A: The board supports an Atheros 8131M WLAN module via a Mini PCI-E interface.
The Quanta GD3 Main Board is an Arrandale platform motherboard featuring an Ibex Peak-M HM55/PM55 PCH. Graphics are handled by a discrete NVIDIA N11M-GE1 GPU with dedicated VRAM. The system uses two unbuffered DDR3 SODIMM slots supporting 800/1066 MHz memory at 1.5V. The embedded controller is a WPC775, and the BIOS is stored on a SPI flash device. Audio is provided by an ALC275 codec. Power management is handled by multiple ICs including the ISL62882 for CPU core, PM6686 for 3VPCU and 5VPCU, OZ8111LN for VCC1.05, and MAX17028 for VCC_CFXCORE. Networking includes an Atheros AR8131M Gigabit LAN controller and an Intel Puma Peak 2x2 AGN WiFi Link 6200 module. A T77H114.11 charging IC manages battery power, and a TCS5B card reader is present. The board also includes a 2MG USB hub controller and TMDSTMDS HDMI level shifting.
A: The embedded controller is a WPC775.
Q: What BIOS flash type is used?
A: The BIOS is stored on a SPI flash device.
Q: What is the GPU configuration?
A: The motherboard uses a discrete NVIDIA N11M-GE1 GPU with dedicated VRAM.
Q: What charging IC is used?
A: The charging IC is a T77H114.11.
Q: What power management ICs are present?
A: Power management ICs include ISL62882 for CPU core, PM6686 for 3VPCU and 5VPCU, OZ8111LN for VCC1.05, and MAX17028 for VCC_CFXCORE.
This Quanta GD3 Main Board, revision 1A, dated August 18, 2009, is an Intel platform motherboard. The schematic includes a dedicated Charger Board, dated August 27, 2009. The design incorporates a Mini PCI-E card slot for WLAN and WWAN modules, with specific power ratings noted for each. The board features a WLAN RF_ON control signal and a WLAN_WAKE# signal. Component changes documented include the addition of Q19 (2N7002K) and R514 (10K) for WLAN WAKE#, and modifications to the ACIN circuit involving resistors PR236, PR237, and transistors PQ70, PQ71. The charger board schematic details the interface between the mainboard and the WLAN/WWAN Mini PCI-E card, including USB, PCIe, and LPC bus connections.
A: The board is identified as the Quanta GD3 Main Board, revision 1A.
A: The motherboard is based on an Intel CPU platform.
Q: What type of expansion slots are documented for wireless connectivity?
A: The schematic documents a Mini PCI-E card slot for WLAN and a separate Mini PCI-E card slot for WWAN.
Q: Are there documented modifications to the ACIN circuit?
A: Yes, the change list includes modifications to the ACIN circuit, specifically changing PR236 to 330K/F, PR237 from 30K/F to 100K/F, deleting PD12, and adding PQ70 and PQ71 (2N7002E-T1-E3).
| Brand | QUANTA COMPUTER |
| Board Number | GD3 Main Board |
| Revision | 1A |
| Date | Tuesday, October 20, 2009 |
| Document Number | Custom17 |
| LAN IC | Atheros AR8131M |
| WiFi / WLAN IC | Atheros 8131M |
| Model | GD3 Main Board |
| Motherboard Manufacturer | QUANTA COMPUTER |
| Revision | Custom333 |
| Date | Monday, June 01, 2009 |
| CPU Platform | Arrandale |
| PCH / Southbridge | Ibex Peak-M HM55/PM55 |
| GPU Type | [URL="https://dr-bios.com/components/gpu/nvidia-n11m-ge1/"]NVIDIA N11M-GE1[/URL] |
| Graphics Architecture | NVIDIA N11M-GE1 |
| EC / KBC | WPC775 |
| Audio Codec | ALC275 |
| BIOS / SPI Flash | SPI BIOS |
| Charging IC | T77H114.11 |
| Power IC(s) | ISL62882, PM6686, OZ8111LN, MAX17028 |
| RAM Type | DDR3 800/1066 1.5V |
| RAM Architecture | UNBUFFERED DDR3 SODIMM |
| WiFi / WLAN IC | Intel Puma Peak 2x2 AGN (Intel WiFi Link 6200) |
| Card Reader IC | TCS5B |
| USB Hub IC | 2MG |
| HDMI Level Shifter | TMDSTMDS |
| Revision | 1A |
| Date | Tuesday, August 18, 2009 |
| CPU Platform | Intel |
| Charger Board Date | Thursday, August 27, 2009 |
GD3 MAIN BOARD
AR8131M
8131M
Arrandale
HM55
PM55
N11M-GE1
Nvidia N11M-GE1
WPC775
ALC275
T77H114.11
ISL62882
MAX17028
OZ8111LN
PM6686
1 5V
DDR3
Puma Peak 2x2 AGN
TCS5B
2MG
Intel
GD3 MAIN BOARD
AR8131M
8131M
Arrandale
HM55
PM55
N11M-GE1
Nvidia N11M-GE1
WPC775
ALC275
T77H114.11
ISL62882
MAX17028
OZ8111LN
PM6686
1 5V
DDR3
Puma Peak 2x2 AGN
TCS5B
2MG
Intel
