sony pcg-51111w qunata gd3-cb-atheros-pvt-1020a 1
This Quanta Computer GD3 Main Board, revision 1A, dated October 20, 2009, is documented under number 1122334455667788AABBCCDD21. The board integrates an Atheros AR8131M LAN IC at U37. The design includes a separate Charger Board, revision M3, dated October 6, 2009, with document number 5544332211DDCCBBAA. A dedicated WLAN/WWAN board, revision 2A, also dated October 6, 2009, is present under document number AABBCCDDEE44332211110. The main board supports Mini PCI-E cards for WLAN and WWAN functionality, with specific power ratings for each slot.
A: The motherboard uses an Atheros AR8131M LAN IC located at U37.
A: The board number is GD3 Main Board, revision 1A, dated October 20, 2009.
Q: What is the document number for this motherboard?
A: The document number is 1122334455667788AABBCCDD21.
| Brand | QUANTA COMPUTER |
| Board Number | GD3 Main Board |
| Revision | 1A |
| Date | Tuesday, October 20, 2009 |
| Document Number | 1122334455667788AABBCCDD21 |
| LAN IC | Atheros AR8131M |
| LAN IC Package | U37 |
| Charger Board | Charger Board |
| Charger Board Date | Tuesday, October 06, 2009 |
| Charger Board Document Number | 5544332211DDCCBBAA |
| Charger Board Revision | M3 |
| WLAN/WWAN Board Date | Tuesday, October 06, 2009 |
| WLAN/WWAN Board Revision | 2A |
| WLAN/WWAN Board Document Number | AABBCCDDEE44332211110 |
