Schematic sony quanta gc8.gc9 diamond-3 intel calpella platform with uma gfx 990304 schematic
sony quanta gc8.gc9 diamond-3 intel calpella platform with uma gfx 990304 1
BrandQuanta Computer Inc.
Project CodeLD-Note Calpella UMA
DateThursday, March 04, 2010
CPU PlatformIntel Calpella Platform with UMA GFX
CPU SocketrPGA 989
PCH / SouthbridgeIbex Peak-M Intel(R) 5 Series Express Chipset
GPU TypeUMA
EC / KBCITE8502
EC/KBC PackageQFN32
Audio CodecALC269Q
BIOS / SPI FlashFLASH 2Mbyts, FLASH 4Mbyts
Charging ICISL88731
Power IC(s)ISL6237IRZ-T, ISL62882, MAX17028, RT8204, TPS51116REGR
RAM TypeDDR3
RAM ArchitectureDual Channel DDR3 800/1067 1.5V
RAM Quantity / SlotsDDR3 - SODIMM0, DDR3 - SODIMM1
LAN ICRTL8111DL
WiFi / WLAN ICMINI-CARD WLAN/WiMAX
HDMI Level ShifterPS8101
Card Reader ICG990P11U
USB Hub ICR5538
This Quanta LD-Note Calpella UMA motherboard is built on the Intel Calpella platform with UMA graphics, featuring an Ibex Peak-M Intel 5 Series PCH and an rPGA 989 CPU socket. The system is managed by an ITE8502 EC/KBC in a QFN32 package. Memory support includes dual-channel DDR3 800/1067 SODIMMs. The board utilizes a FLASH 2Mbyts and FLASH 4Mbyts SPI BIOS configuration. Power management is handled by a suite of ICs including the ISL88731 charger, ISL6237IRZ-T, ISL62882, MAX17028, RT8204, and TPS51116REGR. Integrated peripherals include the ALC269Q audio codec, RTL8111DL LAN controller, PS8101 HDMI level shifter, G990P11U card reader, and R5538 USB hub.
A: The motherboard uses an ITE8502 EC/KBC in a QFN32 package.
Q: What BIOS flash configuration is present?
A: The schematic references two SPI flash devices: a FLASH 2Mbyts and a FLASH 4Mbyts.
A: The board supports dual-channel DDR3 800/1067 memory via two SODIMM slots (DDR3 - SODIMM0 and DDR3 - SODIMM1).
Q: What charging IC is used?
A: The charging IC is an ISL88731.
Q: What is the graphics configuration?
A: This is a UMA (Unified Memory Architecture) configuration with no discrete GPU.
  • Sony=1=Quanta_GC8.GC9_Diamond-3_Intel_Calpella_Platform_with_UMA_GFX_990304.pdf
