sony vaio vgn-bx195 bx196 bx500 quanta rj1_mbx-142 schematic
sony vaio vgn-bx195 bx196 bx500=1=quanta rj1_mbx-142.pdf
The QUANTA COMPUTER RJ1 Main Board, revision 1A136 dated April 22, 2005, is built around the Alviso platform supporting Dothan CPUs at 400/533 MHz FSB. The core chipset consists of the Intel 915GM/915PM graphics and memory controller hub paired with the ICH6-M southbridge. System memory is unbuffered DDRII 400/533 in SO-DIMM form factor. The embedded controller is a National Semiconductor PC97551. Audio is handled by the Realtek ALC260 codec, while the TI-TPA6011A4 serves as both the audio amplifier and charging IC. Networking is provided by the Marvell 88E8053 Gigabit LAN controller. The system includes a VT6212 USB hub and card reader controller, an Intel Calexico II mini-PCI wireless module, and an Infineon SLD 9630 TPM security module. Storage connectivity includes a Silicon Image Sil 3512 SATA controller. Clock generation is managed by the ICS954227 clock generator.
Q: What is the embedded controller used on this motherboard?
A: The embedded controller is the National Semiconductor PC97551.
A: The audio codec is the Realtek ALC260.
A: The LAN controller is the Marvell 88E8053 Gigabit Ethernet controller.
A: The memory architecture is unbuffered DDRII 400/533 in SO-DIMM slots.
| Brand | QUANTA COMPUTER |
| Model | RJ1 Main Board |
| Board Number | RJ1 Main Board |
| Revision | 1A136 |
| Date | Friday, April 22, 2005 |
| CPU Platform | Alviso 400/533 MHz Dothan |
| PCH / Southbridge | ICH6-M |
| GPU Type | 915GM/915PM |
| Graphics Architecture | 915GM/915PM |
| EC / KBC | NS PC97551 |
| Audio Codec | ALC260 |
| Charging IC | TI-TPA6011A4 |
| LAN IC | MARVELL 88E8053 |
| RAM Type | DDRII 400/533 |
| RAM Architecture | UNBUFFERED |
| RAM Quantity / Slots | SO-DIMM |
| Card Reader IC | VT6212 |
| USB Hub IC | VT6212 |
| WiFi / WLAN IC | Intel Calexico II module |
| TPM | Infineon SLD 9630 |
| Clock Generator | ICS954227 |
| SATA Controller | Sil 3512 |
| Audio Amplifier | TI-TPA6011A4 |
RJ1 MAIN BOARD
ICH6-M
915GM/915PM
915GM/915PM
NS PC97551
ALC260
TI-TPA6011A4
MARVELL 88E8053
DDRII 400/533
VT6212
VT6212
ICS954227
Clock Generator
RJ1 MAIN BOARD
ICH6-M
915GM/915PM
915GM/915PM
NS PC97551
ALC260
TI-TPA6011A4
MARVELL 88E8053
DDRII 400/533
VT6212
VT6212
ICS954227
Clock Generator
