sony vaio vgn-fj vgn-fj57c vgn-fj67cw vgn-fj270 fj67 vgn-fj77 quanta rd1-mic 0702b 1
This QUANTA COMPUTER motherboard schematic, dated Saturday, July 02, 2005, incorporates a MAX4232 operational amplifier for audio codec and amplifier functions. Power regulation is handled by a MAX8863 linear regulator IC. The design includes a dedicated MIC board section with a MIC-CON (53261-0490) connector and a secondary MIC-CON (85204-0200) connector. The voltage output is configured via resistor dividers, with Vout calculations based on 1.25V reference and resistor values including 28.7K, 29.4K, and 27K. The board utilizes various passive components including capacitors rated at 10V/Y5V and 10V/X5R dielectrics.
Q: What audio IC is used on this motherboard?
A: The MAX4232 operational amplifier is used for audio codec and amplifier functions.
Q: What power regulation IC is present on this board?
A: The MAX8863 linear regulator is used for power regulation.
| Brand | QUANTA COMPUTER |
| Date | Saturday, July 02, 2005 |
| Audio Codec | MAX4232 |
| Audio Amplifier | MAX4232 |
| Power IC(s) | MAX8863 |
