Schematic toshiba compal ls-3443p nb8e-se ddr3 vga bd rev-1a schematic
toshiba compal ls-3443p nb8e-se ddr3 vga bd rev-1a 1
BrandCompal
Document Number4059G5CS
Revision1.A
Date2007-06-22
CPU PlatformnVIDIA NB8E-SE
GPU TypenVIDIA NB8E-SE
Graphics ArchitectureDDR3
RAM TypeDDR3
RAM Architecture16M*32
RAM Quantity / Slots4 pcs / 8 pcs
Thermal SensorADM1032ARMZ-2REEL
This Compal Electronics schematic, document number 4059G5CS revision 1.A dated 2007-06-22, details the LS-3443P VGA/B motherboard based on the nVIDIA NB8E-SE GPU platform. The graphics architecture utilizes DDR3 frame buffer memory configured as 16M*32, with a quantity of either 4 pcs for 256M or 8 pcs for 512M total capacity. The board integrates an ADM1032ARMZ-2REEL thermal sensor for monitoring. The schematic includes a block diagram showing the NB8x GPU connected to a PCI Express interface, LVDS bus, and DDR3 control signals, with power rails including +VDD_CORE, +1.2VS, +1.5VS, +1.8VS, +2.5VS, and +3.3VS. Memory chips referenced are Samsung K4D553235F-GC2A.
Q: What is the document number and revision of this schematic?
A: The document number is 4059G5CS, revision 1.A, dated 2007-06-22.
Q: What GPU platform is used on this motherboard?
A: The motherboard uses the nVIDIA NB8E-SE GPU platform with DDR3 graphics architecture.
Q: What memory configuration does this board support?
A: The board supports DDR3 frame buffer memory configured as 16M*32, with options for 4 pcs (256M) or 8 pcs (512M) total capacity, using Samsung K4D553235F-GC2A chips.
Q: What thermal sensor is used on this board?
A: The board uses an ADM1032ARMZ-2REEL thermal sensor.
  • Toshiba=1=Compal_LS-3443P_NB8E-SE_DDR3_VGA_Bd_Rev-1A.pdf
