Schematic toshiba inventec chelsea cs10g mp 2091104 ti map schematic
BrandInventec
Motherboard ManufacturerInventec
Project CodeChelsea 10G
Board Number6050A2256201
RevisionA02
Date2009-10-08
CPU PlatformClarkfield / Arrandale
EC / KBCWINB781
Audio CodecALC272
Charging ICBQ24721C
Power IC(s)TPS51125, TPS51218, TPS51621, RT9194, RT8015APQW, PM6652
RAM TypeDDR III
RAM ArchitectureSODIMM0, SODIMM1
LAN ICRTL8103E, RTL8111DP
Card Reader ICRICOH_R5U230
GPU TypeNvidia VGA
Graphics ArchitectureDiscrete Graphic
This Inventec Chelsea 10G motherboard, board number 6050A2256201 revision A02, is designed for the Clarkfield and Arrandale CPU platforms. The system uses DDR III memory in SODIMM0 and SODIMM1 slots. Graphics are handled by a discrete Nvidia VGA solution. The embedded controller is a WINB781, and the audio codec is an ALC272. Power management is handled by a BQ24721C charger IC and multiple power ICs including TPS51125, TPS51218, TPS51621, RT9194, RT8015APQW, and PM6652. Networking is provided by RTL8103E and RTL8111DP LAN ICs, and the card reader controller is a RICOH_R5U230.
A: The embedded controller is a WINB781.
A: The charging IC is a BQ24721C.
Q: What type of memory does this motherboard use?
A: This motherboard uses DDR III memory in SODIMM0 and SODIMM1 slots.
Q: What is the graphics architecture of this motherboard?
A: This motherboard uses a discrete Nvidia VGA graphics solution.
  • Toshiba=Inventec CHELSEA CS10G MP 2091104 TI map.pdf
