toshiba nb550d ls-6851p power btn 1
This Compal Electronics, Inc. document is the schematic for the LS-6851P Power BTN Board, a sub-board associated with the S6851 project. The schematic is identified by document number 405NJICSCHEAMTIC PWR/B S6851, revision 13, dated Tuesday, August 16, 2011. The board functions as a power button interface, connecting to the main motherboard via a 6-pin FFC connector at Z1. The design includes a power button switch SW1, model TJG-533-V-T/R_6P, and associated filtering components. This sub-board schematic provides the interface details for the power button signal, ON/OFFBTN#_RL, routed to the mainboard.
Q: What is the document number for this Compal S6851 power button board schematic?
A: The document number is 405NJICSCHEAMTIC PWR/B S6851, revision 13.
Q: What is the board number for this power button sub-board?
A: The board number is LS-6851P Power BTN Board.
Q: How does this power button board connect to the main motherboard?
A: It connects via a 6-pin FFC connector at reference designator Z1.
| Document Number | 405NJICSCHEAMTIC PWR/B S6851 |
| Revision | 13 |
| Date | Tuesday, August 16, 2011 |
| Board Number | LS-6851P Power BTN Board |
| Project Code | S6851 |
