Schematic toshiba nb550d ls-6852p tp schematic
toshiba nb550d ls-6852p tp 1
BrandCompal
ModelS6852
Project Code405NJJC
Board NumberLS-6852P TP BTN board
Revision1.0
DateMonday, August 15, 2011
Document Number405NJJC
This Compal Electronics, Inc. schematic document, project code 405NJJC, details the LS-6852P TP BTN board for the S6852 model. The document is dated Monday, August 15, 2011, with revision 1.0. The schematic includes a touchpad module interface and main board connections via hot bar FFC connectors with 1.0mm pitch. The board incorporates an APX9132ATI-TRL voltage regulator in a SOT23-3 package. Design notes indicate a component change for ESD request, with U22 changed from SA00001NT00 to SA00001TC00 on 2010.03.29. The schematic also specifies BOM structure components including resistors, capacitors, and switches for the touchpad and lid switch functionality.
Q: What is the board number for this Compal S6852 schematic?
A: The board number is LS-6852P TP BTN board.
Q: What is the project code and document number for this schematic?
A: The project code and document number are both 405NJJC.
Q: What voltage regulator IC is used on this board?
A: The APX9132ATI-TRL in a SOT23-3 package is used.
  • Toshiba_NB550D=1=LS-6852P_TP.pdf
