toshiba satellite c640 6050a2357501-mb-ax1 es 0303 ct10
The Inventec Calcutta 10 motherboard (Board Number 6050A2250801-MB, Revision A1) is built on the Arrandale CPU platform with a Socket-rPGA989 and an Intel HM 55 PCH. The system utilizes DDR III memory in two SODIMM slots. Power management is handled by a MAX17435 charging IC and a suite of power ICs including TPS51218, TPS51621, TPS51125, MAX17480, TSP51217, G5694F11U, PM6652, and SG2997. The embedded controller is a WINB781LCX20671, and the audio codec is from Conexant. Networking is provided by an Atheros WLAN IC and an AR8152-AL1 LAN IC. The clock generator is an IDT ICS9LRS3197AKLF, and the card reader controller is from ENE.
A: The board number is 6050A2250801-MB, Revision A1.
A: The EC/KBC is a WINB781LCX20671.
A: The charging IC is a MAX17435.
Q: What is the CPU platform and PCH on this motherboard?
A: The CPU platform is Arrandale with a Socket-rPGA989, and the PCH is an Intel HM 55.
| Brand | Inventec |
| Model | Calcutta 10 |
| Motherboard Manufacturer | Inventec |
| Project Code | Calcutta10 |
| Board Number | 6050A2250801-MB |
| Revision | A1 |
| Date | 23-Feb-2010 |
| CPU Platform | Arrandale |
| CPU Socket | Socket-rPGA989 |
| PCH / Southbridge | HM 55 |
| EC / KBC | WINB781LCX20671 |
| Audio Codec | CONEXANT |
| Charging IC | MAX17435 |
| Power IC(s) | TPS51218, TPS51621, TPS51125, MAX17480, TSP51217, G5694F11U, PM6652, SG2997 |
| RAM Type | DDR III |
| RAM Architecture | SODIMM |
| LAN IC | AR8152-AL1 |
| WiFi / WLAN IC | Atheros |
| Clock Generator | IDT_ICS9LRS3197AKLF |
| Card Reader IC | ENE |
CALCUTTA10
6050A2250801-MB
Arrandale
HM-55
WINB781LCX20671
MAX17435
G5694F11U
MAX17480
PM6652
SG2997
TPS51125
TPS51218
TPS51621
TSP51217
DDR(III)
AR8152-AL1
ATHEROS
IDT_ICS9LRS3197AKLF
Clock Generator
CALCUTTA10
6050A2250801-MB
Arrandale
HM-55
WINB781LCX20671
MAX17435
G5694F11U
MAX17480
PM6652
SG2997
TPS51125
TPS51218
TPS51621
TSP51217
DDR(III)
AR8152-AL1
ATHEROS
IDT_ICS9LRS3197AKLF
Clock Generator
