Schematic toshiba satellite c640-645 calcutta 10ad ct10ad 6050a2357601-mb-a01 schematic
toshiba satellite c640-645 calcutta 10ad_ct10ad_6050a2357601-mb-a01 schematic
toshiba satellite c640-645=1=calcutta 10ad_ct10ad_6050a2357601-mb-a01.pdf
BrandInventec
ModelCalcutta 10AD
Motherboard ManufacturerInventec
Project CodeCalcutta 10AD
Board NumberCSA3441
RevisionX01
Date7-Apr-2010
CPU PlatformAMD Danube (Champlain)
PCH / SouthbridgeSB820M
GPU TypeRS880M
EC / KBCW781L
Audio CodecConexant CX20671
BIOS / SPI FlashWinbond
LAN ICAtheros AR8152
Charging ICMAX17435
Charger ArchitectureMAX17435 Charger BB
Power IC(s)MAX17480, TPS51217, TPS51218, TPS51125, G5694F11U, G916T1U
RAM TypeDDR3
RAM ArchitectureDDR3_SODIMM0, DDR3_SODIMM1
RAM Quantity / Slots2
Card Reader ICGenesys
USB Hub ICUSB3638
WiFi / WLAN ICAtheros
The Inventec Calcutta 10AD is an AMD Danube (Champlain) platform motherboard featuring an RS880M GPU and SB820M southbridge. The system utilizes two DDR3 SODIMM slots for memory expansion. Power management is handled by a MAX17435 charger architecture with a MAX17480 voltage regulator, alongside TPS51217, TPS51218, TPS51125, G5694F11U, and G916T1U power ICs. The embedded controller is an ITE W781L, and the BIOS SPI flash is supplied by Winbond. Audio is managed by a Conexant CX20671 codec, while networking is provided by an Atheros AR8152 LAN controller and an Atheros WLAN module. Additional I/O includes a Genesys card reader and a USB3638 USB hub controller.
Q: What is the BIOS flash IC manufacturer used on this motherboard?
A: The BIOS SPI flash is supplied by Winbond.
A: The embedded controller is an ITE W781L.
Q: What is the charging IC and architecture on this motherboard?
A: The charging IC is a MAX17435, utilizing a MAX17435 Charger BB architecture.
Q: What CPU platform does this motherboard support?
A: This motherboard supports the AMD Danube (Champlain) CPU platform.
  • Toshiba Satellite C640-645=1=Calcutta 10AD_CT10AD_6050A2357601-MB-A01.zip
