toshiba satellite c660 pwwha la-7202p rev 1.0
The Compal LA-7202P motherboard, revision 1.0, is built around the Intel Sandy Bridge processor platform paired with the Intel PCH Cougar Point - M southbridge. The system firmware is stored on a 4MB SPI ROM, while the embedded controller firmware resides on a separate 128KB EC ROM, managed by the ENE KB930 EC/KBC. Audio is handled by the ALC259 HDA codec, and networking is provided by the RTL8105E 10/100M LAN IC. Memory configuration supports dual-channel DDRIII architecture via two DDRIII-SO-DIMM slots, operating at speeds up to 1600 MT/s. The board also integrates an RTS5137 card reader IC for internal camera support.
A: The ENE KB930 is used as the embedded controller.
A: The board uses a 4MB SPI ROM for the main BIOS and a separate 128KB EC ROM for the embedded controller firmware.
A: The board supports dual-channel DDRIII memory via two DDRIII-SO-DIMM slots.
Q: What LAN IC is used?
A: The Realtek RTL8105E 10/100M Ethernet controller is used.
| Model | LA-7202P |
| Board Number | LA-7202P |
| Date | 2011-02-08 |
| Document Number | PWWHA LA-7202P M/B |
| CPU Platform | Intel Processor (Sandy Bridge) |
| PCH / Southbridge | Intel PCH Cougar Point - M |
| EC / KBC | ENE KB930 |
| Audio Codec | ALC259 |
| BIOS / SPI Flash | SPI ROM (4MB) |
| EC Flash / ROM | EC ROM (128KB) |
| LAN IC | RTL8105E 10/100M |
| RAM Type | DDRIII |
| RAM Quantity / Slots | DDRIII-SO-DIMM X2 |
| Card Reader IC | RTS5137 |
