toshiba satellite m50 compal_la-2861_rev1.0 schematic
toshiba satellite m50=1=compal_la-2861_rev1.0.pdf
The Compal HAZ00/BL10E (LA2861) Rev 1.0 motherboard, dated 2005/07/11, is built around the UFC-PGA Dothan CPU platform with an ATI-RC410MB GPU and ATI-SB450 southbridge. The system uses an ENE KB910 embedded controller and an ALC 250 audio codec. Memory is provided via two SO-DIMM slots supporting DDRII. The board features a 1M BIOS flash, an RTL8100CL LAN controller, a CB1410 card reader, a TSB43AB21 USB hub controller, an ADM1032 thermal sensor, an APA2068 audio amplifier, and an ICS951411AGT clock generator. The charging circuit is handled by a dedicated CHARGER IC.
A: The board number is LA-2861, revision 1.0, dated 2005/07/11.
Q: What embedded controller is used on this motherboard?
A: The embedded controller is an ENE KB910.
Q: What BIOS flash capacity is specified?
A: The BIOS flash is specified as 1M.
A: The LAN controller is an RTL8100CL.
| Model | HAZ00/BL10E (LA2861) |
| Project Code | HAZ00/HTW01 |
| Board Number | LA-2861 |
| Date | 2005/07/11 |
| CPU Platform | UFC-PGA Dothan |
| PCH / Southbridge | ATI-SB450 |
| GPU Type | ATI-RC410MB |
| EC / KBC | ENE KB910 |
| Audio Codec | ALC 250 |
| BIOS / SPI Flash | BIOS(1M) |
| Charging IC | CHARGER |
| RAM Type | DDRII |
| RAM Quantity / Slots | SO-DIMM x 2 |
| LAN IC | RTL8100CL |
| Card Reader IC | CB1410 |
| USB Hub IC | TSB43AB21 |
| Thermal Sensor | ADM1032 |
| Audio Amplifier | APA2068 |
| Clock Generator | ICS951411AGT |
HAZ00
HTW01
LA-2861
Dothan
SB450
RC410MB
KB910
ALC250
DDR2
RTL8100CL
CB1410
TSB43AB21
ADM1032
APA2068
Audio Amplifier
ICS951411AGT
Clock Generator
HAZ00
HTW01
LA-2861
Dothan
SB450
RC410MB
KB910
ALC250
DDR2
RTL8100CL
CB1410
TSB43AB21
ADM1032
APA2068
Audio Amplifier
ICS951411AGT
Clock Generator
