Schematic toshiba satellite p775d ls-7217p 2nd hdd schematic
BrandCompal
ModelLS-7217P
Board NumberLS-7217P
Revision1.0
Date2011/01/28
PCB NameLS-7217P
PCB Revision1.0
Document Number405NO8B
Function2ND HDD/B S7217
Compal P/NDA400010610
This Compal Electronics, Inc. schematic document, designated 405NO8B, details the 2ND HDD/B S7217 sub-board. The PCB is identified as LS-7217P, revision 1.0, with a date of 2011/01/28 and Compal part number DA400010610. The board functions as a secondary hard drive bay interface for the S7217 platform, connecting to the mainboard via an FFC hot-bar connection at JP145. The schematic includes a 2nd HDD/B connector JHDD1 and a SATA connector JHDD2, with power rails including 3.3V, 5V, and 12V.
Q: What is the PCB name and revision for this Compal 2nd HDD board?
A: The PCB is LS-7217P, revision 1.0.
Q: What is the Compal part number for this board?
A: The Compal part number is DA400010610.
Q: What is the document number for this schematic?
A: The document number is 405NO8B.
  • Toshiba Satellite P775D=LS-7217P 2ND HDD.pdf
