toshiba vfkta-rosetta 10ft 10ftg la-9861p r02 20121205 r0.2
This Compal LA-9861P Rev 0.2 schematic, dated 2012-11-14, details a motherboard built around the Intel Ivy Bridge/Sandy Bridge processor platform paired with the Intel PCH Panther Point chipset. The board features dual-channel DDRIII memory via two 200-pin SO-DIMM slots. Graphics are handled by an nVIDIA N14x dGPU. The embedded controller is a KB9012, and the audio codec is an ALC259. System firmware is stored on a SPI ROM configuration of 4MB plus 2MB. Networking is provided by RTL8106E and 8111G LAN ICs, and a GL834L card reader controller is also present.
A: The board number is LA-9861P, and the project code is VFKTA.
A: The embedded controller is a KB9012.
A: The BIOS is stored on a SPI ROM configuration of 4MB plus 2MB.
A: The board uses dual-channel DDRIII memory via two 200-pin SO-DIMM slots.
| Project Code | VFKTA |
| Board Number | LA-9861P |
| Revision | 0.2 |
| Date | 2012-11-14 |
| CPU Platform | Intel Processor (Ivy Bridge/Sandy Bridge) |
| PCH / Southbridge | Intel PCH Panther Point |
| GPU Type | nVIDIA N14x |
| EC / KBC | KB9012 |
| Audio Codec | ALC259 |
| BIOS / SPI Flash | SPI ROM (4MB + 2MB) |
| RAM Type | DDRIII |
| RAM Quantity / Slots | 200pin DDRIII-SO-DIMM X2 |
| Card Reader IC | GL834L |
| LAN IC | RTL8106E & 8111G |
