toshiba vskaa ls-9861p lan usb small board
This Compal Electronics schematic details the LAN and USB section for the LS-9861P PCB, dated 2012/10/25. The primary LAN controller is the Realtek RTL8111G-CG in a QFN32 4x4 package, with an alternate 10/100M 8106E option noted. The design includes a dedicated USB 2.0 port and an RJ45 connector with integrated magnetics, supported by ESD protection components and specific layout guidelines for signal integrity.
Q: What is the primary LAN IC used on this board?
A: The primary LAN IC is the Realtek RTL8111G-CG in a QFN32 4x4 package.
Q: Is there an alternate LAN IC option?
A: Yes, the schematic references an 8106E 10/100M LAN IC as an alternate configuration.
| PCB Name | LS-9861P |
| Date | 2012/10/25 |
| LAN IC | RTL8111G-CG_QFN32_4X4 |
| LAN IC (Alternate) | 8106E 10/100M |
