toshiba vskaa ls-9861p r04 0203
This Compal Electronics, Inc. schematic document, revision 0.1 dated 2012-09-28, details the LS-9862P motherboard under project code VSKAA. The board number is DA2000WU000, and the PCB revision is 0.3. The document focuses on the power button and power LED subsystem, including the ON/OFFBTN# signal and +5VS_PWR_ON_LED rail. ESD protection is provided by an ESDL5V0CC3-2 component in a SOT-23 package. The power button switch is a TJG-533-V-T-R type, and the PCB includes an FFC connector referenced as VSKAA_FFC45.
Q: What is the board number for this Compal LS-9862P motherboard?
A: The board number is DA2000WU000.
Q: What is the PCB revision for the LS-9862P?
A: The PCB revision is 0.3.
Q: What is the project code for this motherboard?
A: The project code is VSKAA.
| Model | LS-9862P |
| Project Code | VSKAA |
| Board Number | DA2000WU000 |
| Revision | 0.1 |
| Date | 2012-09-28 |
| PCB Name | LS-9862P |
| PCB Revision | 0.3 |
