File Request UNLOCK DELL LATITUDE 5420
FactoryPC
GDF40 LA-K491P
Laptop Model
DELL LATITUDE 5420
I need the unlock code for a dell 5420 gdf40 la-k491p whose lock code is
2DFC6M3-8FC8
thank you so much!
FactoryPC
Hola Vahab, hoy reprogramé la bios pero lamentablemente no funcionó, la laptop no tiene video pero prende, los ventiladores aceleran y se apaga y si conecto el cargador muestra los colores RGB y se apaga.
FactoryPC
Hello Vahab, today I reprogrammed the bios but unfortunately it did not work, the laptop does not have video but it turns on, the fans accelerate and it turns off and if you connect the charger it shows RGB colors and turns off.
FactoryPC
The laptop with the original dump works fine, the problem is that when I want to enter any of the bios options it asks me for the unlock code.
FactoryPC
Hello, sorry Vahab, I may have expressed myself wrong, what I meant was that I reprogrammed the bios but unfortunately it did not work, the laptop does not have video but it turns on, the fans accelerate and it turns off and if I connect the charger it shows RGB colors and turns off.
Salimeh Bolboli
  • LA-K491P.zip
