Xiaomi Mi Redmibook Pro 15 HuaQin NB2770 Schematic
The Huaqin NB2770 V4.0 motherboard is designed for the AMD Cezanne FP6 processor (FP6 1140 Ball, 45W) with DDR4-3200 memory down configuration using 8 pieces. The system BIOS is stored on a 128Mb SPI ROM. Embedded controller functions are handled by an ITE 8987 in a BGA128 package. Audio is provided by a Realtek ALC256 HDA codec. The charging architecture is based on the BQ24781 IC. Networking includes a Realtek RTL8111H LAN controller and a Realtek RTL8822CE WLAN/BT module. The board also features a PS8203 USB hub controller, a GL823K card reader, and an IT6563FN HDMI level shifter.
A: The embedded controller is an ITE 8987 in a BGA128 package.
A: The system BIOS is a 128Mb SPI ROM.
A: The board uses DDR4-3200 memory down with 8 pieces of memory.
A: The charging IC is a BQ24781.
Reuse permitted only with source attribution.
| Motherboard Manufacturer | Huaqin Telecom Technology Com., Ltd. |
| Project Name | NB2770 |
| Board Number | NB2770 |
| Revision | V4.0 |
| Date | Thursday, December 24, 2020 |
| CPU Platform | AMD Cezanne FP6 |
| CPU Socket | FP6 1140 Ball |
| CPU Power | 45 Watt |
| EC / KBC | ITE 8987 |
| EC/KBC Package | BGA128, Size: 14x14 (mm) |
| Audio Codec | Realtek ALC256 |
| BIOS / SPI Flash | SPI ROM 128Mb |
| RAM Type | DDR4 |
| RAM Architecture | DDR4-3200, Memory Down 8PCS |
| Charging IC | BQ24781 |
| LAN IC | RTL8111H |
| WiFi / WLAN IC | RTL8822CE |
| USB Hub IC | PS8203 |
| Card Reader IC | GL823K |
| Thermal Sensor | G2898 |
| HDMI Level Shifter | IT6563FN |
