acer aspire 5740_5741 compal_la-5892p_rev1.0 schematic
acer aspire 5740_5741=1=compal_la-5892p_rev1.0.pdf
This Compal LA-5892P motherboard schematic, revision 1.0 dated 2010-01-21, documents the NEW70/80/90/50 platform built around the Intel Arrandale processor with DDRIII memory and the Ibex Peak-M PCH. The board utilizes a UMA graphics architecture and supports two 204-pin DDRIII SO-DIMM slots. The embedded controller is an ENE KB926, and the audio codec is an ALC888. The system employs two SPI ROMs for BIOS storage. Networking is handled by a BCM57780 Gigabit Ethernet controller. The clock generator is specified as either an IDT 9LRS3199AKLFT or a SILEGO SLG8SP587. The card reader and audio amplifier functions are integrated into an APA2051 IC.
Q: What is the board number for this motherboard?
A: The board number is LA-5892P.
A: The embedded controller is an ENE KB926.
Q: What is the BIOS configuration on this motherboard?
A: The motherboard uses two SPI ROMs for BIOS storage.
A: The motherboard supports two 204-pin DDRIII SO-DIMM modules.
| Model | NEW70 / 80 / 90 / 50 |
| Board Number | LA-5892P |
| Date | 2010-01-21 |
| CPU Platform | Intel Arrandale Processor with DDRIII + Ibex Peak-M |
| EC / KBC | ENE KB926 |
| Audio Codec | ALC888 |
| BIOS / SPI Flash | SPI ROM x2 |
| LAN IC | BCM57780 |
| RAM Type | DDRIII |
| RAM Architecture | 204pin DDRIII-SO-DIMM X2 |
| Graphics Architecture | UMA |
| Card Reader IC | APA2051 |
| Clock Generator | IDT: 9LRS3199AKLFT / SILEGO: SLG8SP587 |
| Audio Amplifier | APA2051 |
| Document Number | NEW70 M/B LA-5892P Schematic |
