Schematic acer aspire 5742-5742g pew71 pew91 pew51 la-5894p rev1.0 schematic
acer aspire 5742-5742g pew71 pew91 pew51 la-5894p_rev1.0 schematic
acer aspire 5742-5742g=1=pew71 pew91 pew51 la-5894p_rev1.0.pdf
BrandCompal
ModelPEW71/91/51
Board NumberLA5894P
Revision1.0
Date2010-12-29
Document Number4019COA
CPU PlatformIntel Arrandale Processor with DDRIII + Ibex Peak-M
CPU SocketrPGA988A
PCH / SouthbridgeIbex Peak-M
GPU TypeNV N11P-GV2H and N11P-GE, N12P-GS N12P-GV-OP With Optimus
EC / KBCENE KB926
Audio CodecALC272X (UMA)
BIOS / SPI FlashSPI ROM x1
Charging ICTI TPS6017
RAM TypeDDRIII
RAM Architecture204pin DDRIII-SO-DIMM X2
RAM Quantity / SlotsBANK 0, 1, 2, 3
Card Reader ICRTS5160
LAN ICBCM57780
Clock GeneratorIDT: 9LVS3199AKLFT / Realtek: RTM890N-631-VB-GRT
This Compal LA5894P motherboard, documented under document number 4019COA revision 1.0 dated 2010-12-29, is designed for the PEW71/91/51 platform. It is built around the Intel Arrandale processor with DDRIII memory and the Ibex Peak-M PCH, utilizing an rPGA988A socket. The graphics subsystem features NV N11P-GV2H, N11P-GE, N12P-GS, and N12P-GV-OP configurations with Optimus technology. System management is handled by an ENE KB926 EC/KBC, while the audio codec is an ALC272X for UMA configurations. The board utilizes a single SPI ROM for BIOS storage. Power management includes a TI TPS6017 charging IC. Memory architecture consists of two 204-pin DDRIII SO-DIMM slots across four banks. Peripheral connectivity is supported by a BCM57780 Gigabit LAN controller and an RTS5160 card reader IC. Clock generation is provided by either an IDT 9LVS3199AKLFT or Realtek RTM890N-631-VB-GRT.
A: The EC/KBC is an ENE KB926.
A: The board uses a single SPI ROM for BIOS storage.
A: The board supports two 204-pin DDRIII SO-DIMM modules across four banks (BANK 0, 1, 2, 3).
Q: What GPU configurations are supported?
A: The board supports NV N11P-GV2H, N11P-GE, N12P-GS, and N12P-GV-OP with Optimus technology.
  • Acer Aspire 5742-5742G=1=PEW71 PEW91 PEW51 LA-5894P_Rev1.0.zip
