acer aspire es1-531 wistron domino_ba 14285-1 schematic
domino_ba_-1_20150320.pdf
This Wistron Domino-1 motherboard, project code 4PD053010001 with PCB P/N 14285 revision -163, is built around the Intel Braswell CPU platform. The system BIOS is stored on an MX25U6473F SPI flash IC. Embedded controller functionality is handled by an NPCE985P KBC. Audio is provided by a Realtek ALC255 codec, while networking is managed by a Realtek RTL8111 LAN IC and a Mini-Card WLAN & BT combo module. The charging circuit uses an HPA02224 charger IC, and power regulation is handled by a combination of RT6575, NCP81201MNTXG, TPS51716, RT8068AZQW, and RT9043GB ICs. Memory configuration consists of one DDR3L 1333MHz Channel A slot. A GL850G USB hub and card reader controller is present. The integrated graphics are driven by the CPU's GFX_CORE.
Q: What BIOS flash IC is used on this motherboard?
A: The BIOS SPI flash is an MX25U6473F.
A: The embedded controller is an NPCE985P.
Q: What is the charging IC on this board?
A: The charger IC is an HPA02224.
Q: What is the memory configuration for this motherboard?
A: The board supports one DDR3L 1333MHz Channel A slot.
| Brand | Wistron |
| Project Code | 4PD053010001 |
| Board Number | Domino-1 |
| Revision | -163 |
| Date | Friday, March 20, 2015 |
| Document Number | A31102 |
| CPU Platform | Braswell |
| EC / KBC | NPCE985P |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | MX25U6473F |
| Charging IC | HPA02224 |
| Power IC(s) | RT6575, NCP81201MNTXG, TPS51716, RT8068AZQW, RT9043GB |
| RAM Type | DDR3L |
| RAM Architecture | 1333MHz Channel A |
| RAM Quantity / Slots | 1 Slot |
| LAN IC | Realtek RTL8111 |
| WiFi / WLAN IC | Mini-Card WLAN & BT comb module |
| Card Reader IC | GL850G |
| USB Hub IC | GL850G |
| GPU Type | Intel CPU |
| Graphics Architecture | GFX_CORE |
4PD053010001
DOMINO-1
Braswell
NPCE985P
ALC255
HPA02224
NCP81201MNTXG
RT6575
RT8068AZQW
RT9043GB
TPS51716
DDR3L
RTL8111
GL850G
GL850G
Intel CPU
GFX CORE
4PD053010001
DOMINO-1
Braswell
NPCE985P
ALC255
HPA02224
NCP81201MNTXG
RT6575
RT8068AZQW
RT9043GB
TPS51716
DDR3L
RTL8111
GL850G
GL850G
Intel CPU
GFX CORE
