Schematic acer ls-4221p jala0 rev 1.0 fp board schematic
acer ls-4221p_jala0_rev 1.0 fp board schematic
compal ls-4221p (jala0) rev 1.0 fp board.pdf
BrandCompal
Model NameLS-4221P
Board NumberLS4221FPB
Revision1.0
Date2008/4/10
PCB NameLS-4221P FP/B
Document Number4059L8
EC / KBCTCS4EA-6A-0_BGA27
EC/KBC PackageBGA27
EC Flash / ROMM95256-WMN6TP_SO8
USB Hub ICMAX4785EXK+T_SC70_5
Crystal12MHZ_16P_DSX840GA
This Compal Electronics LS-4221P front panel board, revision 1.0, dated April 10, 2008, is built around the TCS4EA-6A-0 EC/KBC controller in a BGA27 package. The EC firmware is stored on an M95256-WMN6TP serial EEPROM in an SO8 package. The board also features a MAX4785EXK+T USB hub IC in a SC70-5 package and is clocked by a 12MHz DSX840GA crystal. The PCB is identified as LS-4221P FP/B with document number 4059L8.
Q: What EC/KBC controller is used on this board?
A: The board uses a TCS4EA-6A-0 controller in a BGA27 package.
Q: What EC flash/ROM IC is used?
A: The EC firmware is stored on an M95256-WMN6TP serial EEPROM in an SO8 package.
Q: What USB hub IC is present?
A: The board uses a MAX4785EXK+T USB hub IC in a SC70-5 package.
  • Acer=1=LS-4221P_JALA0_Rev 1.0 FP Board.zip
