acer travel mate p449 pegatron p4 gddr5
This Pegatron P4 Skylake U (2+2) motherboard, project KTKUG_25W revision 1.1 dated September 6, 2016, is built around an Intel Skylake U-series CPU platform with an Nvidia N16S-GT discrete GPU using GDDR5 frame buffer memory. The system memory architecture consists of DDR4 memory down x4 plus one SO-DIMM slot. The embedded controller is an IT8987E/BX, and the BIOS is stored on a 16M SPI ROM. The audio subsystem uses a Realtek ALC255 codec, while networking is handled by an Intel I219 LAN controller and an NGFF WLAN/WiGig module. Display connectivity includes an Analogix ANX7428 USB Type-C controller, a Parade PS8338B DP switch, and a Realtek RTD2166 DP to VGA converter. USB 3.0 signal integrity is maintained by a TI SN65LVPE512 redriver, and SATA 3 by a Parade PS8527B redriver. Additional I/O includes a Genesys GL850G USB 2.0 hub, a Realtek RTS5229 card reader, an RTS5170 smart card reader, and an NPCT650 TPM module.
A: The BIOS is stored on a 16M SPI ROM.
A: The embedded controller is an IT8987E/BX.
Q: What is the GPU configuration on this motherboard?
A: The motherboard uses an Nvidia N16S-GT discrete GPU with GDDR5 frame buffer memory.
A: The memory architecture is DDR4 with memory down x4 and one SO-DIMM x1 slot.
Q: What USB-C controller is used on this motherboard?
A: The USB Type-C controller is an Analogix ANX7428.
| Brand | Pegatron |
| Project Name | KTKUG_25W |
| Revision | 1.1 |
| Date | Tuesday, September 06, 2016 |
| CPU Platform | P4 Skylake U (2+2) |
| EC / KBC | IT8987E/BX |
| Audio Codec | Realtek ALC255 |
| BIOS / SPI Flash | 16M SPI ROM |
| Card Reader IC | RTS5229 |
| LAN IC | Intel I219 |
| WiFi / WLAN IC | NGFF WLAN / WiGig |
| GPU Type | Nvidia N16S-GT |
| Graphics Architecture | GDDR5 |
| Charging IC | BATTERY CHARGER |
| RAM Type | DDR4 |
| RAM Architecture | Memory Down x4 + SO-DIMM x1 |
| USB Hub IC | GENESYS GL850G |
| HDMI Level Shifter | PS8338B |
| USB-C Controller | ANALOGIX ANX7428 |
| DP to VGA Converter | Realtek RTD2166 |
| USB 3.0 Redriver | TI SN65LVPE512 |
| SATA 3 Redriver | PARADE PS8527B |
| K2K Repeater | PS8203 |
| TPM | NPCT650 |
| Card Reader (Smart) | RTS5170 |
