acer zejv4 la-a411p r01 0304 cheetah-ct
This Compal LA-A411P motherboard, revision 0.1, is designed for the Acer Cheetah_CT tablet based on the Intel Clover Trail platform. The system is powered by a PMIC and uses PSNB5072A1ZNBT power ICs. Memory consists of 2GB LPDDR2 in a CO-POP configuration. The BIOS SPI flash is a Winbond W25Q32 4Mbit IC. Embedded controller functionality is handled by an ENE IO3737. Audio is managed by a Realtek ALC5642 codec, while charging is controlled by a TI BQ24192 charger IC paired with a TI BQ27541 fuel gauge. The board features a Renesas UPD60802A HDMI level shifter, a TI TUSB1211 ULPI PHY for USB, and a Realtek SDIN5C4-64GB eMMC for storage. Wireless connectivity is provided by a WIFI/BT combo module.
A: The BIOS SPI flash is a Winbond W25Q32 4Mbit IC.
A: The embedded controller is an ENE IO3737.
Q: What is the charging architecture of this motherboard?
A: The charging circuit uses a TI BQ24192 charger IC and a TI BQ27541 fuel gauge.
Q: What type of memory does this motherboard use?
A: The board uses 2GB of LPDDR2 memory in a CO-POP configuration.
| Brand | Acer |
| Model | Cheetah_CT |
| Board Number | LA-A411P |
| Revision | 0.1 |
| Date | 2013-03-04 |
| CPU Platform | Intel Clover Trail |
| EC / KBC | ENE IO3737 |
| Audio Codec | ALC5642 |
| BIOS / SPI Flash | Winbond W25Q32 |
| BIOS Flash Exact Model | W25Q32 |
| BIOS Flash Manufacturer | Winbond |
| BIOS Flash Capacity | 4Mbit |
| Charging IC | TI/BQ24192 |
| Charger Architecture | TI/BQ24192 |
| Power IC(s) | PSNB5072A1ZNBT |
| RAM Type | LPDDR2 |
| RAM Architecture | CO-POP |
| RAM Quantity / Slots | 2GB |
| Card Reader IC | Realtek Sandsisk SDIN5C4-64GB |
| LAN IC | TI/TUSB1211 |
| WiFi / WLAN IC | WIFI/BT Combo |
| HDMI Level Shifter | Renesas UPD60802A |
