apple apple m39 dvt imac g5 isight 20 051-6950 rev 06 111605
This Apple Computer Inc. motherboard, drawing number 051-6950, is designed around a 2.5GHz CPU platform with a 1.2V/800MHz core. The system architecture features an M56 GPU and an H8S/2116 EC/KBC. Memory is provided by two DDR2 DIMM slots operating in dual-channel 64-bit mode at 1.8V/667MHz. The BIOS is stored on an RMT BootROM SPI flash. Networking is handled by a Yukon Gigabit Ethernet controller and an Airport WLAN module. Audio processing is managed by an STA9221 codec. The board includes a U4800 Flash Controller for media card support. Power management is distributed across multiple ICs including U100 for charging and U8900, U8950, U9000, and U9050 for core voltage regulation. Thermal monitoring is provided by a U6100 GPU+NB temperature sensor and a U1000 CPU temperature sensor.
Q: What is the drawing number for this Apple motherboard?
A: The drawing number is 051-6950.
A: The EC/KBC is an H8S/2116.
Q: What type of BIOS flash is used?
A: The BIOS is stored on an RMT BootROM SPI flash.
A: The board supports two DDR2 DIMM slots in dual-channel 64-bit mode at 1.8V/667MHz.
Q: What GPU is used on this motherboard?
A: The GPU is an M56.
| Brand | Apple Computer Inc. |
| Motherboard Manufacturer | Apple Computer Inc. |
| Drawing Number | 051-6950 |
| Date | 11/16/05 |
| CPU Platform | 2.5GHZ 1.2V/800MHZ CORE |
| GPU Type | M56 |
| EC / KBC | H8S/2116 |
| Audio Codec | STA9221 |
| BIOS / SPI Flash | RMT BOOTROM SPI |
| LAN IC | YUKON GIG ETHERNET |
| RAM Type | DDR2 - DUAL CHAN (1.83/2.17GHZ) |
| RAM Architecture | 64-BIT 1.8V/667MHZ |
| RAM Quantity / Slots | 2 DIMM’S |
| Card Reader IC | U4800 FLASH CTLR |
| WiFi / WLAN IC | AIRPORT |
| Charging IC | U100 |
| Power IC(s) | U8900, U8950, U9000, U9050 |
| Thermal Sensor | U6100 GPU+NB TSENS, U1000 CPU TSENS |
2.5GHz 1.2V/800MHz Core
M56
H8S/2116
STA9221
U4800 FLASH CTLR
AIRPORT
U100
U8900
U8950
U9000
U9050
U1000 CPU TSENS
U6100 GPU+NB TSENS
M56
H8S/2116
STA9221
U4800 FLASH CTLR
AIRPORT
U100
U8900
U8950
U9000
U9050
U1000 CPU TSENS
U6100 GPU+NB TSENS
