apple imac g5 a1058 m39 mlb img5 051-6482 rev c
This Apple Computer Inc. motherboard, drawing number 051-6482C revision C dated 08/04/04, is built around the U3LITE CPU platform. The system architecture integrates an NV18B/NV34 GPU, a PCM3052 audio codec, and a BCM5221 10/100 Ethernet PHY. USB 2.0 connectivity is provided by a uPD720101 USB hub IC. The block diagram details HyperTransport, AGP 8X, SATA/150, UATA/133, FireWire A, and PCI interfaces. Memory architecture includes main memory DIMMs and graphics DDR SDRAM frame buffers. The design also incorporates a PULSAR clock generator and Shasta core logic components.
Q: What is the drawing number for this Apple motherboard?
A: The drawing number is 051-6482C.
Q: What CPU platform is used on this motherboard?
A: The CPU platform is U3LITE.
Q: What GPU is used on this motherboard?
A: The GPU is an NV18B/NV34.
A: The audio codec is a PCM3052.
Q: What Ethernet PHY is used on this motherboard?
A: The Ethernet PHY is a BCM5221.
| Brand | Apple Computer Inc. |
| Motherboard Manufacturer | Apple Computer Inc. |
| Drawing Number | 051-6482C |
| Revision | C |
| Date | 08/04/04 |
| CPU Platform | U3LITE |
| GPU Type | NV18B/NV34 |
| Audio Codec | PCM3052 |
| LAN IC | BCM5221 |
| USB Hub IC | uPD720101 |
