apple imac g5 a1058 m39 mlb img5_051-6482_revc schematic
apple imac g5 a1058=1=m39 mlb img5_051-6482_revc.pdf
This Apple Computer Inc. motherboard schematic, drawing number 051-6482C, dated 08/03/04, is built around the U3LITE CPU platform. The system architecture integrates an NV18B/NV34 GPU for graphics processing. Audio functionality is provided by a PCM3052 audio codec. Networking is handled by a BCM5221 10/100 Ethernet PHY. The block diagram details a comprehensive system layout including HyperTransport, AGP, PCI, FireWire, USB, SATA, and Ethernet interfaces, along with memory and graphics subsystems.
Q: What is the drawing number for this Apple motherboard?
A: The drawing number is 051-6482C.
Q: What CPU platform is used on this motherboard?
A: The CPU platform is U3LITE.
A: The audio codec is a PCM3052.
Q: What Ethernet PHY is used on this motherboard?
A: The Ethernet PHY is a BCM5221.
| Brand | Apple Computer Inc. |
| Motherboard Manufacturer | Apple Computer Inc. |
| Date | 08/03/04 |
| Drawing Number | 051-6482C |
| CPU Platform | U3LITE |
| Audio Codec | PCM3052 |
| LAN IC | BCM5221 |
| GPU Type | NV18B/NV34 |
