Hello.
I try to repair a laptop ASUS F555L which turns on but has no image on screen or via HDMI. It has motherboard X555LD REV 3.3, it also has on board ram and also a separate RAM slot (i tried other working RAM).
It draws 0.65A when turned on, fan is spinning.
I downloaded the repair guide and boardview for this model from Dr. BIOS and checked every coil and signal spot and all voltages and signals are normal as they should.
I know bios is integrated in EC but i have no programmer.
Is there any way to check if BIOS is ok, with some kind of signal? EC_RST, PLT_RST, RSM_RST signals are 3.3v which seem to be ok.
Any ideas for what else to check? Thank you in advance.
