clevo-axioo_w251huq_w252hum_w255hum w240humb-0d schematic
w251huq_w240humb-0d.pdf
This Gigabyte motherboard, board number 6-71-E51QS-D02 at EVT revision 9/20, is built on the Sandy Bridge platform with an rPGA989/988 socket and a CougarPoint PCH. The integrated graphics architecture uses Intel FDI. System memory consists of two DDR3 SO-DIMM slots. The embedded controller is a W83L771AWG in a 128-pin LQFP package, which also serves as the thermal sensor. Audio is handled by an ALC269/VT1802P codec. Networking includes an ITE 8518E LAN IC and a JMC251 C WLAN controller. A uPD720200 IC manages the card reader, and an NEC USB hub IC is present.
A: The board number is 6-71-E51QS-D02 at EVT revision 9/20.
A: The EC/KBC is a W83L771AWG in a 128-pin LQFP package.
Q: What memory architecture does this motherboard support?
A: This motherboard supports DDR3 memory in two SO-DIMM slots.
A: The audio codec is an ALC269/VT1802P.
| Brand | Gigabyte |
| Model | 6-71-E51QS-D02 |
| Motherboard Manufacturer | Gigabyte |
| Board Number | 6-71-E51QS-D02 |
| Revision | 9/20 EVT |
| CPU Platform | Sandy Bridge |
| CPU Socket | rPGA989/988 |
| PCH / Southbridge | CougarPoint Platform Controller Hub (PCH) |
| GPU Type | Integrated |
| Graphics Architecture | Intel(R) FDI |
| EC / KBC | W83L771AWG |
| EC/KBC Package | 128 pins LQFP |
| Audio Codec | ALC269/VT1802P |
| RAM Type | DDR3 |
| LAN IC | ITE 8518E |
| WiFi / WLAN IC | JMC251 C |
| Card Reader IC | uPD720200 |
| USB Hub IC | NEC |
| Thermal Sensor | W83L771AWG |
