I HAVE A 450 G3 MOTHERBOARD THAT IS NOT POWERING ON
WHEN I PLUG POWER THE CHARGING PORT ANDPOWER BUTTONLIGHTS ON BUT NOTHING AFTER THAT
5V AND 3V PRESENT.
PLEASE HELP
5V AND 3V PRESENT.
PLEASE HELP
you must check all voltage of before boot . Follow the steps in the Power Block Diagram.
PWRBTN# signal must be pulled up , check it . motherboard must be turn on with pull down this signal . program bios is first step . good luck
