dell 6 hm170 d7- sff5 rev a00 2015.07.29
This Foxconn D7A00 revision 1 motherboard, dated June 29, 2015, is built on the Intel Sky Lake Platform with an SLK PCH-H southbridge. The board supports DDR4 memory across four slots configured as CHA0 DIMM3, CHA1 DIMM1, CHB0 DIMM4, and CHB1 DIMM2. Audio is handled by an ALC3234 codec, and wired networking is provided by an RTK RTL8111HSD LAN IC. The power delivery subsystem is complex, utilizing multiple regulators including NCP81203MNTXG and NCP81166MNTBG3 for VCORE and VCCGT, AOZ2236QI-02 and AOZ2238QI-02 switchers, RT8237EZQW controllers, and an APL5325BI-TRG linear regulator. USB charging is managed by a PERICOM PI5USB2546AZHE IC. The board also includes a thermal sensor on the SFF3 configuration.
A: The board number is D7A00, and the project code is Scorpion/Spitfire/Toledo.
Q: What CPU platform and PCH does this motherboard use?
A: This motherboard uses the Intel Sky Lake Platform with an SLK PCH-H southbridge.
Q: What audio codec and LAN IC are used on this board?
A: The audio codec is an ALC3234, and the LAN IC is an RTK RTL8111HSD.
A: The board supports DDR4 memory across four slots: CHA0 DIMM3, CHA1 DIMM1, CHB0 DIMM4, and CHB1 DIMM2.
| Brand | Foxconn |
| Project Code | Scorpion/Spitfire/Toledo |
| Board Number | D7A00 |
| Revision | 1 |
| Date | Monday, June 29, 2015 |
| CPU Platform | Intel Sky Lake Platform |
| PCH / Southbridge | SLK PCH-H |
| Audio Codec | ALC3234 |
| LAN IC | RTK RTL8111HSD |
| RAM Type | DDR4 |
| RAM Architecture | CHA0 DIMM3, CHA1 DIMM1, CHB0 DIMM4, CHB1 DIMM2 |
| RAM Quantity / Slots | 4 |
| Charging IC | PERICOM PI5USB2546AZHE |
| Charger Architecture | USB CHARGING |
| Power IC(s) | NCP81203MNTXG, NCP81166MNTBG3, AOZ2236QI-02, AOZ2238QI-02, RT8237EZQW, AP22802AW5-7, NCP51200MNTXG, APL5325BI-TRG, RT6575BGQW, AZ34063UMTR-G1 |
| Thermal Sensor | THERMAL SENSOR (SFF3) |
| USB Hub IC | PERICOM PI5USB2546AZHE |
