dell_inspiron_3520 dv15_mlk_(11280-1)dr-bios.com dell_inspiron_3520 dv15_mlk(11280-1)_dr-bios.com schematic
dell inspiron 3520=dv15 mlk (11280-1).pdf
This Wistron Corporation Enrico/Caruso 15 HRX01 motherboard, project code 91.4IP01.01 and board number 48.4IP16.0SB, revision 10316-1, is dated June 2, 2011. It is built on the Intel Sandy Bridge CPU platform paired with the Intel Cougar Point PCH. The system uses UMA graphics and supports dual-channel DDRIII 1066/1333 memory across two DIMM slots. The embedded controller is a NUVOTON NPCE795P, and the audio codec is an IDT 92HD87B1. The BIOS is stored on a 4MB Flash ROM. Power management is handled by a BQ24707 charging IC and multiple DC/DC converters including ISL95831HRTZ, TPS51216RUKR, TPS51123RGER, TPS51218, TPS51311RGTR, and TPS51461. Connectivity includes a Realtek RTS5138 card reader, Realtek RTL8105E and RTL8111E-VB LAN ICs, and an 802.11b/g/n BT V3.0+HS wireless module.
A: The BIOS is stored on a 4MB Flash ROM.
A: The embedded controller is a NUVOTON NPCE795P.
A: The charging IC is a BQ24707.
A: The motherboard supports dual-channel DDRIII 1066/1333 memory across two DIMM slots.
| Model | Enrico/Caruso 15 HRX01 |
| Project Code | 91.4IP01.001 |
| Board Number | 48.4IP16.0SB |
| Revision | 10316-1 |
| Date | Thursday, June 02, 2011 |
| CPU Platform | Intel Sandy Bridge |
| PCH / Southbridge | Intel Cougar Point |
| GPU Type | UMA |
| EC / KBC | NUVOTON NPCE795P |
| Audio Codec | IDT 92HD87B1 |
| BIOS / SPI Flash | Flash ROM 4MB |
| Charging IC | BQ24707 |
| Power IC(s) | ISL95831HRTZ, TPS51216RUKR, TPS51123RGER, TPS51218, TPS51311RGTR, TPS51461 |
| RAM Type | DDRIII 1066/1333 |
| Card Reader IC | Realtek RTS5138 |
| LAN IC | Realtek RTL8105E, Realtek RTL8111E-VB |
| WiFi / WLAN IC | 802.11b/g/n BT V3.0+HS |
91.4IP01.001
48.4IP16.0SB
Intel Sandy Bridge
UMA
NPCE795P
IDT 92HD87B1
BQ24707
ISL95831HRTZ
TPS51123RGER
TPS51216RUKR
TPS51218
TPS51311RGTR
TPS51461
DDRIII 1066/1333
RTS5138
RTL8105E
RTL8111E-VB
91.4IP01.001
48.4IP16.0SB
Intel Sandy Bridge
UMA
NPCE795P
IDT 92HD87B1
BQ24707
ISL95831HRTZ
TPS51123RGER
TPS51216RUKR
TPS51218
TPS51311RGTR
TPS51461
DDRIII 1066/1333
RTS5138
RTL8105E
RTL8111E-VB
