Schematic dell inspiron 8500 compal la-1351 rev x04 schematic
dell inspiron 8500 compal_la-1351_rev x04 schematic
dell inspiron 8500=1=compal_la-1351_rev x04.pdf
BrandDell
ModelInspiron Precision
Project CodeLindbergh/Baekland
Board NumberADQ00/LA-1351
RevisionX04
DateWednesday, January 08, 2003
CPU PlatformuFCPGA Northwood
PCH / SouthbridgeICH4-M
GPU TypeNV28/ATI M9
EC / KBCPC87570
Audio CodecSTAC9750
BIOS / SPI FlashSST39VF080
Charging ICMAX1645
Power IC(s)MAX1632
RAM TypeDDR
RAM ArchitecturePC2100
RAM Quantity / SlotsSO-DIMM X2
Thermal SensorADM1032
Card Reader ICPCI4510/PC7510
LAN ICNIC 5705M/4401
This Dell Inspiron Precision motherboard, manufactured by Compal Electronics, Inc., is based on the Lindbergh/Baekland project with board number ADQ00/LA-1351 revision X04. The platform utilizes a uFCPGA Northwood CPU with an ICH4-M southbridge. Graphics are handled by an NV28/ATI M9 GPU. The system BIOS is stored on an SST39VF080 flash IC. Embedded controller functions are managed by a PC87570 EC/KBC. Audio is provided by a STAC9750 AC97 codec. The charging architecture is built around a MAX1645 charger IC, with power regulation handled by a MAX1632. Memory configuration supports DDR PC2100 via two SO-DIMM slots. System monitoring is performed by an ADM1032 thermal sensor. The board integrates a PCI4510/PC7510 card reader controller and a NIC 5705M/4401 LAN IC.
A: The BIOS flash IC is an SST39VF080.
A: The embedded controller is a PC87570.
A: The charging IC is a MAX1645.
A: The memory architecture is DDR PC2100, supporting two SO-DIMM slots.
Q: What thermal sensor is used on this motherboard?
A: The thermal sensor is an ADM1032.
  • Dell Inspiron 8500=1=compal_la-1351_Rev x04.zip
