destinycenter
Greetings. Thank you for all the trainings you've made available for us. I've really been learning a lot just these few months I started watching them.
This Dell in question comes on with battery when charged. The customer used to charge it on a similar machine before putting it into this one. I've confirmed this by using my power supply to supply battery voltage from the battery connector and it comes on.
But when I plug adapter voltage, nothing happens. Power Supply amps is 0.01/0.02. The main power rail is present. But strangely the 3.3v on the power button isn't present.
I also checked the Power management chipset which is intersil 9538h w736nu. I couldn't find the datasheet online, but got a previous model whose pins corresponded. The ACIN pin here which is the detection pin here is present but ACOK is not present. My suspect is the PWM chip.
