dell latitude e5410 e5510 df3 14d 09281-sb x01 1102 1 1
The Wistron Fonseca 14.1" DIS motherboard, project code 91.4GQ01.001 with board number 91.4GQ01.0SB revision X01, is built around the Intel Ibex Peak-M platform supporting an rPGA988A socket for Mobile Arrandale CPUs. Graphics are handled by an ATI M92-LP discrete GPU with dedicated DDR3 VRAM. The embedded controller is an ECE 1077, and system audio is provided by an IDT92HD81 Azalia CODEC. The BIOS is stored on a 64Mb SPI flash. Power management is handled by a TI BQ24745 battery charger, with system DC/DC conversion managed by ISL62883, TPS51116, TPS51511, TPS51125, and TPS51218 regulators, alongside RT9035 LDOs. Memory architecture supports two DDR3 DIMM slots across Channel A and Channel B. The board integrates a BCM5761E LAN controller, an R5U242 card reader, and a MAX4885EETG HDMI level shifter.
A: The BIOS is stored on a 64Mb SPI flash.
A: The embedded controller is an ECE 1077.
A: The battery charger is a TI BQ24745.
Q: What is the discrete GPU on this motherboard?
A: The discrete GPU is an ATI M92-LP.
| Model | Fonseca 14.1" DIS |
| Project Code | 91.4GQ01.001 |
| Board Number | 91.4GQ01.0SB |
| Revision | X01 |
| Date | Monday, November 02, 2009 |
| CPU Platform | Intel Ibex Peak-M |
| CPU Socket | rPGA988A |
| GPU Type | ATI M92-LP |
| EC / KBC | ECE 1077 |
| Audio Codec | IDT92HD81 Azalia CODEC |
| BIOS / SPI Flash | SPI FLASH 64Mb |
| Charging IC | TI BQ24745 |
| Charger Architecture | BATTERY CHARGER BQ24745 |
| Power IC(s) | ISL62883, TPS51116, TPS51511, TPS51125, TPS51218, RT9035 |
| RAM Type | DDR III |
| RAM Architecture | Channel A, Channel B |
| RAM Quantity / Slots | DIMM1, DIMM2 |
| Card Reader IC | R5U242 |
| LAN IC | BCM5761E |
| WiFi / WLAN IC | WLAN Switch |
| HDMI Level Shifter | MAX4885EETG |
91.4GQ01.001
91.4GQ01.0SB
Ibex Peak-M
M92-LP
ECE1077
IDT92HD81 AZALIA CODEC
BQ24745
ISL62883
RT9035
TPS51116
TPS51125
TPS51218
TPS51511
DDR3
R5U242
BCM5761E
MAX4885EETG
91.4GQ01.001
91.4GQ01.0SB
Ibex Peak-M
M92-LP
ECE1077
BQ24745
ISL62883
RT9035
TPS51116
TPS51125
TPS51218
TPS51511
DDR3
R5U242
BCM5761E
MAX4885EETG
