dell latitude e5410 e5510 df3 14d fonseca-1 0322 1 09281- 1 r-1 1
The Wistron Fonseca 14.1" DIS-1 motherboard, project code 91.4GQ01.001 and board number 48.4GQ01.011 revision 09281-1, is built around the Intel Ibex Peak-M PCH supporting an rPGA988A Arrandale mobile CPU. Graphics are handled by an ATI M92-LP discrete GPU with 512MB of GDDR3 VRAM. The system uses two DDR3 DIMM slots configured as Channel A and Channel B. The embedded controller is an ECE 1077 with a MEC 5045 package. The BIOS is stored on a 32Mb plus 16Mb SPI flash configuration. The audio subsystem uses an IDT92HD81 Azalia CODEC. Power management includes a TI BQ24745 battery charger and multiple DC/DC converters including ISL62883, TPS51116, TPS51511, TPS51125, RT9035, and TPS51218. Networking is provided by a BCM5761E LAN controller and an AES2880 WLAN module. The HDMI interface uses a MAX4885EETG level shifter, and the card reader is a R5U242.
A: The motherboard uses a SPI flash configuration consisting of a 32Mb and a 16Mb flash device.
A: The embedded controller is an ECE 1077 with a MEC 5045 package.
Q: What is the discrete GPU configuration?
A: The motherboard uses an ATI M92-LP GPU with 512MB of GDDR3 VRAM configured as 64Mx16bx4.
| Model | Fonseca 14.1" DIS-1 |
| Project Code | 91.4GQ01.001 |
| Board Number | 48.4GQ01.011 |
| Revision | 09281 - 1 |
| Date | Monday, March 22, 2010 |
| CPU Platform | Intel Ibex Peak-M |
| CPU Model | Intel Mobile CPU Arrandale |
| CPU Socket | rPGA988A |
| PCH / Southbridge | Intel Ibex Peak-M |
| GPU Type | ATI M92-LP |
| Graphics Architecture | GDDR3 800MHz 64Mx16bx4 (512MB) VRAM |
| EC / KBC | ECE 1077 |
| EC/KBC Package | MEC 5045 |
| Audio Codec | IDT92HD81 Azalia CODEC |
| BIOS / SPI Flash | SPI FLASH 32Mb + 16Mb |
| Charging IC | TI BQ24745 |
| Charger Architecture | BATTERY CHARGER BQ24745 |
| Power IC(s) | ISL62883, TPS51116, TPS51511, TPS51125, RT9035, TPS51218, TPS51511 |
| RAM Type | DDR III |
| RAM Architecture | Channel A, Channel B |
| RAM Quantity / Slots | DIMM1, DIMM2 |
| Card Reader IC | R5U242 |
| LAN IC | BCM5761E |
| WiFi / WLAN IC | AES2880 |
| HDMI Level Shifter | MAX4885EETG |
91.4GQ01.001
48.4GQ01.011
Ibex Peak-M
CPU Model
M92-LP
ECE1077
IDT92HD81 AZALIA CODEC
BQ24745
ISL62883
RT9035
TPS51116
TPS51125
TPS51218
TPS51511
DDR3
R5U242
BCM5761E
AES2880
MAX4885EETG
91.4GQ01.001
48.4GQ01.011
Ibex Peak-M
CPU Model
M92-LP
ECE1077
BQ24745
ISL62883
RT9035
TPS51116
TPS51125
TPS51218
TPS51511
DDR3
R5U242
BCM5761E
AES2880
MAX4885EETG
