dell latitude e5410 e5510 wistron df3_fonseca14 dis_09281- 1 schematic
df3_14d_fonseca-1_09281- 1 r-1.pdf
This Wistron Fonseca 14.1" DIS motherboard, project code 91.4GQ01.001 with board number 48.4GQ01.011 revision 09281 - 1, is built on the Intel Ibex Peak-M platform supporting an Intel Mobile CPU Arrandale in an rPGA988A socket. Graphics are handled by an ATI M92-LP with 512MB of GDDR3 VRAM. The system uses DDR III memory across two DIMM slots configured as Channel A and Channel B. The embedded controller is an ECE 1077 with an ECE 5045 package. BIOS storage consists of SPI FLASH in 32Mb and 16Mb configurations. The charging architecture is managed by a TI BQ24745 battery charger. Power regulation is handled by a suite of ICs including ISL62883, TPS51116, TPS51511, TPS51125, TPS51218, and RT9035. Audio is provided by an IDT92HD81 Azalia CODEC, networking by a BCM5761E LAN IC, and HDMI level shifting by a MAX4885EETG.
Q: What BIOS flash configuration is used on this motherboard?
A: The motherboard uses SPI FLASH in 32Mb and 16Mb configurations.
A: The embedded controller is an ECE 1077 with an ECE 5045 package.
Q: What is the charging IC and architecture on this motherboard?
A: The charging IC is a TI BQ24745, configured as a battery charger.
Q: What is the memory architecture on this motherboard?
A: The motherboard supports DDR III memory across two DIMM slots, configured as Channel A and Channel B.
Technical data structured and organized by Dr-Bios.com, based on original
| Model | Fonseca 14.1" DIS |
| Project Code | 91.4GQ01.001 |
| Board Number | 48.4GQ01.011 |
| Revision | 09281 - 1 |
| Date | Monday, March 22, 2010 |
| CPU Platform | Intel Ibex Peak-M |
| CPU Model | Intel Mobile CPU Arrandale |
| CPU Socket | rPGA988A |
| PCH / Southbridge | Intel Ibex Peak-M |
| GPU Type | ATI M92-LP |
| Graphics Architecture | GDDR3 800MHz 64Mx16bx4 (512MB) VRAM |
| EC / KBC | ECE 1077 |
| EC/KBC Package | ECE 5045 |
| Audio Codec | IDT92HD81 Azalia CODEC |
| BIOS / SPI Flash | SPI FLASH 32Mb + 16Mb |
| Charging IC | TI BQ24745 |
| Charger Architecture | BATTERY CHARGER BQ24745 |
| Power IC(s) | ISL62883, TPS51116, TPS51511, TPS51125, TPS51218, RT9035 |
| RAM Type | DDR III |
| RAM Architecture | Channel A, Channel B |
| RAM Quantity / Slots | DIMM1, DIMM2 |
| Card Reader IC | R5U242 |
| LAN IC | BCM5761E |
| WiFi / WLAN IC | WLAN Switch |
| HDMI Level Shifter | MAX4885EETG |
91.4GQ01.001
48.4GQ01.011
Ibex Peak-M
CPU Model
M92-LP
ECE1077
IDT92HD81 AZALIA CODEC
BQ24745
ISL62883
RT9035
TPS51116
TPS51125
TPS51218
TPS51511
DDR3
R5U242
BCM5761E
MAX4885EETG
91.4GQ01.001
48.4GQ01.011
Ibex Peak-M
CPU Model
M92-LP
ECE1077
BQ24745
ISL62883
RT9035
TPS51116
TPS51125
TPS51218
TPS51511
DDR3
R5U242
BCM5761E
MAX4885EETG
