Dell XPS 15-9575 LA FERRARI DAZ10 LA-F211P Rev 1.0 Schematic
This Dell/Compal DAZ10 La Ferrari (KABY LAKE-G) motherboard, board number LA-F211P revision 1.0 (A00) dated 2018-02-26, is built around an Intel Kaby Lake-G processor with a Kaby Lake-H-PCH. The system utilizes dual-channel DDR4 memory down configuration with four x16 memory chips. The embedded controller is a MEC 5105DP C-stepping, and the audio codec is an ALC3271. The BIOS is stored on a 32MB SPI flash. Charging is managed by CY CCG5 PD controllers, and the system includes an Intel Alpine Ridge LAN/WiFi solution with a WLAN+BT4.1 LGA module. The card reader is an RTS5242, and the DP hub is a VMM3320.
A: The board number is LA-F211P, revision 1.0 (A00).
A: The EC/KBC is a MEC 5105DP C-stepping.
A: The BIOS is stored on a 32MB SPI flash.
A: The memory architecture is dual-channel DDR4 with memory down (x16) * 4.
| Brand | Dell/Compal |
| Model | DAZ10 La Ferrari (KABY LAKE-G) |
| Board Number | LA-F211P |
| Revision | 1.0 (A00) |
| Date | 2018-02-26 |
| CPU Platform | Kaby Lake-G |
| PCH / Southbridge | Kaby Lake-H-PCH |
| GPU Type | Intel |
| EC / KBC | MEC 5105DP C-stepping |
| Audio Codec | ALC3271 |
| BIOS / SPI Flash | SPI Flash (BIOS 32MB) |
| Charging IC | CY CCG5 |
| RAM Type | DDR4 |
| RAM Architecture | Dual Channel Memory Bus (DDR4) |
| RAM Quantity / Slots | Memory down (x16) * 4 |
| Card Reader IC | RTS5242 |
| LAN IC | Intel Alpine Ridge |
| WiFi / WLAN IC | WLAN+BT4.1 (16x12mm LGA module) |
| HDMI Level Shifter | DP HUB VMM3320 |
