Finty Logo
$10/mo $1/mo for 6 months ⏳🎁
Pay just $6 instead of $60 — Save $54!
All-in-one software for repair, inventory & accounting — cloud-based, fast & affordable.
File Request GDA31 LA-J144P
shobdoo
monsur
SO I FIND THE RESISTOR ITS 100OHM
So i find the cap.It was 100ohm Resistor.the laptop turned on but no lcd and nop fan.Only keyboard backlight and dell logoapears.Then i try the new BIOS flash and the laptop dead.So this BIOS maybe not compatible.Please help me.here i am uploded the original BIOS backup.
i tried the orginal bios from backup and the laptop is working but the same error ,manufacting mode active.The error log showing its service tag error,there is no service tag.Please repair me the orginal backup with the service tag
shobdoo
monsur
with this orginal backup the laptop is working but as same the manufacturin mode active and there is no service tag.the error apears for the service tag.please help me to fix the servce tag.
ST : 67ZZ9K3
EX : 13544389155
in this device there is no way to fix service tag with bios editing
it should be done in bios settings
shobdoo
monsur
i have tried write it on bios mode but after restart its in the same situation
there is no other solution for that
this file working with service tag and everything fine but the issue is not recognizing hard disk.Maybe another file will work.:unsure:
hard disk problem can't be solve with new bios
a new bios may work even worse
try new hard disk or format current hard and check
shobdoo
monsur
find this one in google search and worked perfectly.Solved
  • La-J144p_rev_1.0_Dell_new_outimage.bin
