Gigabyte GA-B150-HD3 DDR3-WP Rev 1.0 Schematic
The Gigabyte GA-B150-HD3 DDR3 motherboard, revision 1.0, is built on the Intel LGA1151 (Skylake) platform with a PCH B150 southbridge. The board utilizes an ITE8628 EC/KBC and features a Realtek ALC892 audio codec. Storage and firmware are managed via a SPI Dual BIOS configuration with 128M capacity. Networking is handled by an Intel I219 LAN IC. Power regulation is provided by ISL95856 controllers for PWM, Vcore, and VccGT, alongside RT8237 components for PCH and DDR rails. The memory architecture supports DDR3 across four DIMM slots. Video output conversion is managed by an RTD2168 HDMI level shifter, while the ITE8892 and ITE8892E/J handle card reader and USB hub functions respectively.
Q: What is the BIOS configuration on this motherboard?
A: The motherboard uses a SPI Dual BIOS configuration with 128M capacity.
Q: What EC/KBC controller is used?
A: The board uses an ITE8628 EC/KBC controller.
A: The board supports DDR3 memory across four DIMM slots, configured as DDRIV DIMM X 2 in two channels.
The Gigabyte GA-B150M-HD3 DDR3-WP motherboard, revision 1.0, is built on the Intel LGA1151 platform with a B150 PCH. It features a dual BIOS architecture utilizing a 64M SPI flash. The embedded controller is an ITE8628 LPC I/O. Audio is handled by a Realtek ALC887 codec, while networking is provided by a Realtek 8111H LAN IC and a Realtek 8111G WLAN IC. The board supports DDR3 memory across two DIMM slots. A PTN3356 IC serves as the HDMI level shifter, and an ASM1083 controller manages the PCI slot and card reader functions.
Q: What is the BIOS architecture on this motherboard?
A: The board uses a SPI Dual BIOS configuration with a total capacity of 64M.
A: The embedded controller is an ITE8628 LPC I/O.
Q: What audio codec is present?
A: The audio codec is a Realtek ALC887.
Q: What LAN and WLAN ICs are used?
A: The LAN IC is a Realtek 8111H, and the WLAN IC is a Realtek 8111G.
| Brand | Gigabyte Technology |
| Model | GA-B150-HD3 DDR3 |
| Motherboard Manufacturer | Gigabyte Technology |
| Board Number | GA-B150-HD3 DDR3 |
| Date | Friday, August 21, 2015 |
| CPU Platform | [URL="https://dr-bios.com/components/cpu-platform/intel-lga1151/"]Intel LGA1151 (Skylake)[/URL] |
| PCH / Southbridge | PCH (B150) |
| EC / KBC | ITE8628 |
| Audio Codec | Realtek ALC892 |
| BIOS / SPI Flash | SPI Dual BIOS (128M) |
| LAN IC | Intel I219 |
| Power IC(s) | ISL95856 (PWM), ISL95856 (Vcore), ISL95856 (VccGT), RT8237_PCH_BEAD, RT8237_DDR_BEAD |
| RAM Type | DDR3 |
| RAM Architecture | DDRIV DIMM X 2, DDRIV DIMM X 2 |
| RAM Quantity / Slots | 4 |
| HDMI Level Shifter | RTD2168 |
| Card Reader IC | ITE8892 |
| USB Hub IC | ITE8892E/J |
| WiFi / WLAN IC | Realtek ALC892F |
| Model | GA-B150M-HD3 DDR3-WP |
| Board Number | GA-B150M-HD3 DDR3-WP |
| Date | Tuesday, October 13, 2015 |
| CPU Platform | Intel LGA1151 |
| Audio Codec | Realtek ALC887 |
| BIOS / SPI Flash | SPI Dual BIOS (64M) |
| LAN IC | Realtek 8111H |
| RAM Type | DDR3 |
| RAM Architecture | DDRIII DIMM X 1, DDRIII DIMM X 1 |
| Card Reader IC | ASM1083 |
| WiFi / WLAN IC | Realtek 8111G |
| HDMI Level Shifter | PTN3356 |
GA-B150-HD3 DDR3
PCH (B150)
ITE8628
ALC892
/ I219
ISL95856 (PWM)
ISL95856 (VCCGT)
ISL95856 (VCORE)
RT8237_DDR_BEAD
RT8237_PCH-BEAD
DDR3
RTD2168
ITE8892
ITE8892E/J
Realtek ALC892F
Intel LGA1151
ALC887
8111H
ASM1083
Realtek 8111G
PTN3356
GA-B150-HD3 DDR3
PCH (B150)
ITE8628
ALC892
/ I219
ISL95856 (PWM)
ISL95856 (VCCGT)
ISL95856 (VCORE)
RT8237_DDR_BEAD
RT8237_PCH-BEAD
DDR3
RTD2168
ITE8892
ITE8892E/J
Realtek ALC892F
Intel LGA1151
ALC887
8111H
ASM1083
Realtek 8111G
PTN3356
