Schematic gigabyte ga-h81m-d3h schematic
gigabyte ga-h81m-d3h_dr-bios.com gigabyte ga-h81m-d3h_dr-bios.com schematic
gigabyte=ga-h81m-d3h.pdf
BrandGigabyte Technology
ModelGA-H81M-D3H
Motherboard ManufacturerGigabyte Technology
Board NumberGA-H81M-D3H
Revision1.0
Date2014/01/02
CPU PlatformIntel LGA1150
CPU SocketLGA1150
PCH / SouthbridgePCH (H81)
EC / KBCITE8620
Audio CodecRealtek ALC887
BIOS / SPI FlashDUAL BIOS (32M)
LAN ICRealtek RTL8111F
RAM TypeDDRIII
RAM ArchitectureDDRIII DIMM X 2
RAM Quantity / SlotsDDRIII DIMM X 2
GPU TypeIntel LGA1150
Graphics ArchitectureRGB, DVI, HDMI
Charging ICISL95812
Power IC(s)ISL95812, RT8120
Card Reader ICITE IT8892
USB Hub ICUSB 3.0
WiFi / WLAN ICRealtek RTL8111F
HDMI Level ShifterIT8892
The Gigabyte GA-H81M-D3H motherboard, revision 1.0, is built around the Intel LGA1150 CPU platform and PCH H81 chipset. It features dual BIOS with 32M capacity, an ITE8620 EC/KBC, and a Realtek ALC887 audio codec. The board supports DDRIII memory across two DIMM slots and integrates Realtek RTL8111F for LAN. Graphics output is handled via RGB, DVI, and HDMI interfaces. Power management includes ISL95812 and RT8120 ICs, while the ITE IT8892 manages card reader and HDMI level shifting functions.
Q: What BIOS configuration is used on this motherboard?
A: This motherboard uses a dual BIOS configuration with 32M capacity.
A: The motherboard uses an ITE8620 EC/KBC controller.
A: The motherboard uses a Realtek ALC887 audio codec.
A: The motherboard uses a Realtek RTL8111F LAN controller.
  • Gigabyte=GA-H81M-D3H_DR-BIOS.COM.zip
