Gigabyte X470 AORUS ULTRA GAMING Schematic
The Gigabyte X470 AORUS ULTRA GAMING motherboard, revision 1.01, dated September 27, 2018, is built on the AMD X470 platform with project code U17160 and board number 9MX47ARUG-00-10I. The system is managed by an IT8792 EC/KBC, while audio processing is handled by a Realtek ALC1220VB codec. Networking is provided by an Intel I211AT LAN controller. The board utilizes an ISL95712 PWM controller for CPU power delivery and an IDT 9FGL1214AKLF clock generator. USB 3.1 Type-C connectivity is supported via an HD3SS3220 multiplexer, and an ASM1143 controller provides additional USB 3.1 ports. System monitoring and hardware management are performed by an IT8686A Super I/O.
A: The motherboard uses an IT8792 EC/KBC.
A: The motherboard uses a Realtek ALC1220VB audio codec.
A: The motherboard uses an Intel I211AT LAN controller.
Q: What clock generator is used on this motherboard?
A: The motherboard uses an IDT 9FGL1214AKLF clock generator.
| Brand | Gigabyte |
| Model | X470 AORUS ULTRA GAMING |
| Motherboard Manufacturer | Gigabyte |
| Project Code | U17160 |
| Board Number | 9MX47ARUG-00-10I |
| Revision | 1.01 |
| Date | Thursday, September 27, 2018 |
| CPU Platform | AMD X470 |
| EC / KBC | IT8792 |
| Audio Codec | Realtek ALC1220VB |
| LAN IC | Intel I211AT |
| Charging IC | ISL95712 |
| USB Hub IC | ASM1143 |
| HDMI Level Shifter | HD3SS3220 |
| Clock Generator | IDT 9FGL1214AKLF |
| Super I/O | IT8686A |
