HP 15-F0xxx Quanta U87 U88 Schematic
The Quanta U87NB5 project is an Intel Bay Trail-M platform motherboard documented on November 18, 2013, with document number 1A. The platform utilizes a BGA1170 package CPU measuring 25 x 27 mm and features integrated UMA graphics. System memory consists of two DDR3L SODIMM slots, each supporting up to 8GB. The embedded controller is an EnE KB3940 in a 14 x 14 mm LQPF128 package. Audio is handled by a Realtek ALC3227-GR codec in a 6 x 6 mm MQFN package, while networking is provided by a Realtek RTL8176EH-CG LAN controller in a 6 x 6 mm OFN48 package. A Realtek RTS5237-GR card reader in a 7 x 7 mm LQPF48 package is included. Display output supports an eDP interface via a RTD2132R converter in a QFN-32 package. The board also integrates an Intel Rambo Peak USB3.0 hub, a Halt Mini Card WLAN/BT combo module, and a TCP-15G24 G-sensor. The PCB is a 6-layer stack-up.
Q: What embedded controller is used on this motherboard?
A: The embedded controller is an EnE KB3940 in a 14 x 14 mm LQPF128 package.
A: The audio codec is a Realtek ALC3227-GR in a 6 x 6 mm MQFN package.
Q: What LAN controller is used on this motherboard?
A: The LAN controller is a Realtek RTL8176EH-CG in a 6 x 6 mm OFN48 package.
| Brand | Quanta |
| Project Code | U87NB5 |
| Document Number | 1A |
| Date | Monday, November 18, 2013 |
| CPU Platform | Intel Bay Trail-M |
| CPU Package | BGA1170 |
| CPU Size | 25 X 27 (mm) |
| EC / KBC | EnE KB3940 |
| EC/KBC Package | LQPF128 |
| EC/KBC Size | 14 x 14 (mm) |
| Audio Codec | ALC3227-GR |
| Audio Codec Package | MQFN |
| Audio Codec Size | 6 x 6 (mm) |
| LAN IC | RTL8176EH-CG |
| LAN IC Package | OFN48 |
| LAN IC Size | 6 x 6 (mm) |
| Card Reader IC | RTS5237-GR |
| Card Reader IC Package | LQPF48 |
| Card Reader IC Size | 7 x 7 (mm) |
| RAM Type | DDR3L |
| RAM Architecture | SODIMM |
| RAM Quantity / Slots | 2 |
| RAM Max per Slot | 8GBs |
| Graphics Architecture | UMA |
| eDP Converter | RTD2132R |
| eDP Converter Package | QFN-32 |
| USB3.0 HUB | Intel Rambo Peak |
| WLAN / BT Combo | Halt Mini Card |
| G-Sensor | TCP-15G24 |
| PCB Layer Count | 6L |
