Schematic HP 15-F0xxx Quanta U87 U88 Schematic
BrandQuanta
Project CodeU87NB5
Document Number1A
DateMonday, November 18, 2013
CPU PlatformIntel Bay Trail-M
CPU PackageBGA1170
CPU Size25 X 27 (mm)
EC / KBCEnE KB3940
EC/KBC PackageLQPF128
EC/KBC Size14 x 14 (mm)
Audio CodecALC3227-GR
Audio Codec PackageMQFN
Audio Codec Size6 x 6 (mm)
LAN ICRTL8176EH-CG
LAN IC PackageOFN48
LAN IC Size6 x 6 (mm)
Card Reader ICRTS5237-GR
Card Reader IC PackageLQPF48
Card Reader IC Size7 x 7 (mm)
RAM TypeDDR3L
RAM ArchitectureSODIMM
RAM Quantity / Slots2
RAM Max per Slot8GBs
Graphics ArchitectureUMA
eDP ConverterRTD2132R
eDP Converter PackageQFN-32
USB3.0 HUBIntel Rambo Peak
WLAN / BT ComboHalt Mini Card
G-SensorTCP-15G24
PCB Layer Count6L
The Quanta U87NB5 project is an Intel Bay Trail-M platform motherboard documented on November 18, 2013, with document number 1A. The platform utilizes a BGA1170 package CPU measuring 25 x 27 mm and features integrated UMA graphics. System memory consists of two DDR3L SODIMM slots, each supporting up to 8GB. The embedded controller is an EnE KB3940 in a 14 x 14 mm LQPF128 package. Audio is handled by a Realtek ALC3227-GR codec in a 6 x 6 mm MQFN package, while networking is provided by a Realtek RTL8176EH-CG LAN controller in a 6 x 6 mm OFN48 package. A Realtek RTS5237-GR card reader in a 7 x 7 mm LQPF48 package is included. Display output supports an eDP interface via a RTD2132R converter in a QFN-32 package. The board also integrates an Intel Rambo Peak USB3.0 hub, a Halt Mini Card WLAN/BT combo module, and a TCP-15G24 G-sensor. The PCB is a 6-layer stack-up.
Q: What embedded controller is used on this motherboard?
A: The embedded controller is an EnE KB3940 in a 14 x 14 mm LQPF128 package.
A: The audio codec is a Realtek ALC3227-GR in a 6 x 6 mm MQFN package.
A: The LAN controller is a Realtek RTL8176EH-CG in a 6 x 6 mm OFN48 package.
  • HP 15-F0xxx Quanta U87 U88 Schematic.pdf
